I am using Ubuntu 18.04. I am facing a LAN connection problem which I posted on this community 3 times before but didn't get answers. The problem is when I start my laptop it will connect to the LAN but once I disconnect it it won't reconnect. Then I will have to put the laptop in sleep mode and then it would reconnect. Every time I reinstalled Ubuntu and the problem didn't showed up for the first 3-4 days and then again the same problem happens.
But this time I think I have figured out the reason behind this. there was no issue till today when I installed tlp and started it. Only after tlp it showed the same problem again. I googled and got to know that tlp activation changes some settings in order to save battery. Is it possible that tlp is the culprit. If so is there any way I can disable a particular setting so that tlp keeps working and I get rid of the problem.
And yes I have my laptop dual booted with windows 10 and there is no such issue in windows 10. So certainly it is specific to Ubuntu.
Output of
lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
    Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:832b]
    Kernel driver in use: r8169
    Kernel modules: r8169
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:d723]
    Subsystem: Hewlett-Packard Company Device [103c:8319]
    Kernel driver in use: rtl8723de
After this I suspended and ran lspci and I got this
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Skylake Processor Thermal Subsystem (rev 02)
00:08.0 System peripheral: Intel Corporation Skylake Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Device 9d4e (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430] (rev 83)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
Please note that I am not having tlp installed right now. Because of this problem I removed it.
