Ethernet does not resume after suspend.
sudo service network-manager restart
does not work. Only restart solves problem.
The main Ubuntu bug tracking this issue, at least for network kernel module r8169, seems to be:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1752772
I'd encourage everyone that is affected by this issue to go there and mark that it affects you, so that the maintainers have a better sense of how serious it is.
I'm running a fresh install of Xubuntu 18.04, and my Ethernet interface uses kernel module r8169, which I discovered running:
sudo lshw -C network
There'll be 2 groups of info, one starting with description: Ethernet interface, and another with description: Wireless interface. Under description: Ethernet interface, look for a line starting with configuration:, like this:
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.100.6 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
The driver will be here: driver=.
Systemd runs all executable scripts under /lib/systemd/system-sleep before and after suspend, passing 2 parameters, $1 is the state (pre, before suspend, or post, after suspend), and $2 is the action (suspend, hibernate, hybrid-state, or suspend-then-hibernate). This is documented in the man page for systemd-suspend.service.
We need to reload the module for the Ethernet interface when resuming from suspend, after suspend. So I created script /lib/systemd/system-sleep/r8169-refresh:
#!/bin/bash
PROGNAME=$(basename "$0")
state=$1
action=$2
function log {
logger -i -t "$PROGNAME" "$*"
log "Running $action $state"
if [[ $state == post ]]; then
modprobe -r r8169 \
&& log "Removed r8169" \
&& modprobe -i r8169 \
&& log "Inserted r8169"
fi
and made it executable:
chmod +x /lib/systemd/system-sleep/r8169-refresh
The messages logged from the script will go to /var/log/syslog tagged with the name of the script and its PID. This way you can check whether the script reloaded the kernel module:
grep r8169-refresh /var/log/syslog
Here's another simple(r?) solution: create a systemd service whose only task is to unload/reload the module after a suspend cycle (I named it /etc/systemd/system/fix-r8169.service):
[Unit]
Description=Fix RTL-8169 Driver on resume from suspend
After=suspend.target
[Service]
User=root
Type=oneshot
ExecStartPre=/sbin/modprobe -r r8169
ExecStart=/sbin/modprobe r8169
TimeoutSec=0
StandardOutput=syslog
[Install]
WantedBy=suspend.target
Then just execute systemctl enable fix-r8169.service, and you should be set!! Systemd will now automagically unload-and-reload your module upon wake from suspend.
Cheers!
I had the same problem and i found this solution.
run: sudo lshw -C network
to find your network card kernel module
In *-network, description: Ethernet interface, in configuration field found
driver=sky2 for me. sky2 is a ethernet network kernel module for my laptop.
I create a file sky2.sh into: /lib/systemd/system-sleep/ folder with
#!/bin/bash
modprobe -r sky2 # unload sky2 kernel module
modprobe -i sky2 # reload sky2 kernel module
and change the permissions with:
sudo chmod a+x sky2.sh
After that the problem solved.
It detects the Ethernet Connection?
then
open NetworkManager.conf
sudo nano /etc/NetworkManager/NetworkManager.conf
Comment (Add #) the dns=dnsmasq
[main]
plugins=ifupdown,keyfile,ofono
#dns=dnsmasq
[ifupdown]
managed=true
Restart the Network manager
i solved this broblem on my Ubuntu 18.04 Bionic by updating kernel from 4.15 to 4.20 (the latest on 16.01.2019) using UKUU
to install the latest kernel install Ubuntu Kernel Update Utility
sudo add-apt-repository ppa:teejee2008/ppa
sudo apt-get install ukuu
disable access control with the following command:
sudo xhost +
then install with ukuu
sudo ukuu
sudo ukuu --install-latest
and reboot
sudo reboot
I am on Ubuntu 24.04 LTS. My laptop also encountered this issue after recovering from a suspend. My Ethernet is down, despite lshw -C network showing the interface.
This is the solution I found to work:
Use lspci -v | less to show the PCI devices and their kernel modules.
In the less program, find the keyword: Ethernet controller. My output looks like this:
00:1f.6 Ethernet controller: Intel Corporation Device 550b (rev 20)
Subsystem: Lenovo Device 382b
Flags: bus master, fast devsel, latency 0, IRQ 151, IOMMU group 17
Memory at 8a300000 (32-bit, non-prefetchable) [size=128K]
Capabilities: <access denied>
Kernel driver in use: e1000e
Kernel modules: e1000e
Here I can see that e1000e is the module name.
Use modprobe to reload the module:
sudo modprobe -r e1000e
sudo modprobe e1000e
Now my ethernet is working again.
I don't have enough reputation to comment or upvote the accepted answer (which is now outdated)
If you run lsmod | grep r8169 and it shows that you have the r8169 kernel module loaded, and your kernel is older than 4.15.0-24-generic then you are most likely affected by the bug linked in the accepted answer
BTW I experienced this bug and for me lspci | grep 'Gigabit Ethernet' shows
RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
This bug has been fixed.
If your kernel is older than 4.15.0-24-generic, just run
apt-get update
apt-get upgrade
apt-get dist-upgrade
reboot
I had the same problem but the solutions here did not work for me. I spent days going through several forums on this subject and tried just about everything. Two alternative solutions are mentioned, upgrade the Kernel or install the previous module driver. I chose the latter and installed the r8168 driver. Initially, that also failed. However, I discovered something that works and adapted it to the solution from Paulo.
I'm running (K)ubuntu 18.04 with Kernel 4.15.0-24-generic.
The output from lshw -C network includes this ...
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:05:00.0
logical name: enp5s0
version: 0c
serial: 80:fa:5b:49:69:b3
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.045.08-NAPI duplex=full ip=192.168.10.213 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:133 ioport:e000(size=256) memory:df000000-df000fff memory:d0000000-d0003fff
I installed the package r8168-dkms, however that was not enough. Two further steps were required.
Step 1) Edit the file /etc/modprobe.d/r8168-dkms.conf and enable the line (i.e. remove the comment) blacklist r8169
Step 2) Based on the solution from Paulo I created the following script /lib/systemd/system-sleep/r8168-refresh
#!/bin/bash
state=$1
action=$2
function log {
log "ifconfig down enp5s0"
ifconfig enp5s0 down
log "ifconfig up enp5s0"
ifconfig enp5s0 192.168.10.213
fi
This code is of course specific to my machine (device name and IP-address). It could certainly be improved but it meets my needs at the moment.
This works will with NetworkManager.
This happened to me as well with a Gigabyte-B250M-DS3H motherboard after upgrading from Ubuntu 16.04 to 18.04 on July 28, 2018. The kernel is 4.15.0-29-generic.
The result of sudo lshw -C network showed RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller, while it showed that r8169 is the driver used.
What finally worked was installing the driver specific to the Ethernet controller (big surprise):
sudo apt install r8168-dkms
and then restarting the computer (Thanks andypotter). I did not have to blacklist r8169, but I did still have to create a script in /lib/systemd/system-sleep/ that I called r8168-refresh-after-suspend(a la Paulo's advice) that would remove and reinsert r8168:
#!/bin/bash
# $1 is the state (pre or post)
# $2 is the action (suspend)
case $1/$2 in
pre/suspend)
modprobe -r r8168
post/suspend)
modprobe -i r8168
esac
and, of course, make it executable with:
sudo chmod +x /lib/systemd/system-sleep/r8168-refresh-after-suspend
This worked like a charm. So, this is still an issue in the 4.15.0-29 kernel, but the band-aid fix still works.
I have the same problem (driver=r8169), Ethernet does not work after resume from suspend.
It works perfectly well with kernel 4.13.0-31. In other words the Ethernet continues to work after resuming from suspend.
But with kernel 4.15.0-32 the Ethernet does not work after resuming from suspend. I have tried the fix
modprobe -r r8169
modprobe -i r8169
but this has no effect.
I have reported this to https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1752772
I denote that the several Fix file script (modified to my Ethernet adapter) on /lib/systemd/system-sleep/ each works!
Nevertheless, if the cable-Modem device is turned-Off after Suspend, and this is returned-On after Resume system, the Ubuntu based system cannot reconnect to Internet, in spite of network icon (in notification area) shows connection On.
To fix it again, I must clicking on network icon » Ethernet connection. Thus, it refreshes the connection successfully. x-¿
Ethernet controller: VIA Technologies, Inc. VT6105/VT6106S [Rhine-III]
Subsystem: D-Link System Inc DFE-520TX Fast Ethernet PCI Adapter
Kernel driver in use: via-rhine
Kernel modules: via_rhine
P.S. It seems that some vpn's CLI stop working after returning from Suspension.
First thing to check : restart the network manager / service :
If it does not works, check other answers in this post
Had the same problems with my Dell Inspiron 15: no wired network after reboot or suspend.
I seem to have fixed this by changing a setting in the BIOS:
Advanced -> Intel (R) Smart Connect Technology -> Disabled
(default is Enabled)
As a side effect, the menu item has disappeared, to appear again after resetting all settings to default values.
For Dell XPS 7590, it's the same command but a different adaptor:
sudo modprobe -r r8152
sudo modprobe -i r8152
I found a new solution for ubuntu 20.04 LTS on a mbp using a thunderbolt2 to ethernet connection, where the other answers were not working very well.
I tried the commands:
modprobe -r <ethernet-driver>
modprobe -i <ethernet-driver>
in both the following systemd locations as listed in previous answers, but it still wasn't working.
I found the solution was to run both network manager and systemd-networkd using ens9 (Thunderbolt interface) in /etc/netplan, but more importantly disable network manager, and disconnect thunderbolt from command line before suspend & hibernate, and start network manager and connect thunderbolt from command line after suspend and hibernate. Network manager seemed to cause hibernate to always reboot, and the thunderbolt when connected caused the suspend to lock and require a hard reboot.
I added a 2nd file to the /etc/netplan to the standard network manager, to also allow the use of systemd-networkd, as suggested in this post: Using Apple Thunderbolt 2 Ethernet adapter on Ubuntu 20.04
/etc/netplan/01-network-manager-all.yaml
network:
version: 2
renderer: NetworkManager
/etc/netplan/99_config.yaml
network:
version: 2
renderer: networkd
ethernets:
ens9:
dhcp4: true
optional: true
After examining the tg3 ethernet driver and the ens9 thunderbolt with the following commands looking at the kernel, systemd, etc logs:
journalctl | grep tg3 | tail -30
journalctl | grep ens9 | tail -30
dmesg --time-format ctime | grep -a tg3 | tail -n 30
journalctl -u systemd-networkd | grep tg3 | tail -30
grep tg3 -a /var/log/syslog | tail -40
and trying the suspend/hibernate pm_test, where suspend no longer worked even with pm_test set to [platform], which didn't help much, and where the commands are located here: https://www.kernel.org/doc/html/latest/power/basic-pm-debugging.html
more /sys/power/disk
more /sys/power/state
more /sys/power/pm_test
echo freezer | sudo tee /sys/power/pm_test
echo devices | sudo tee /sys/power/pm_test
echo platform | sudo tee /sys/power/pm_test
I used the following commands to test the ethernet connection (and wifi):
ifconfig
speedtest-cli
I found that stopping the network manager, which took the wifi driver out of (ifconfig) allowed hibernate to take place without reboot:
### pre-1
sudo systemctl stop NetworkManager.service
### post-1
sudo systemctl start NetworkManager.service
confirm the status of network manager
systemctl status NetworkManager.service
ifconfig
speedtest-cli
where I stopped the network manager before suspend and before hibernate, at which point it disabled wifi, but ethernet was still working, and started after suspend and hibernate at which point wifi would be up again.
Next I worked on how to disconnect the thunderbolt by command line, since I had found that when the computer was only on wifi and the thunderbolt-ethernet cable was not physically connected, I was able to suspend and wake the computer. I found the following commands after a long search were able to disconnect the thunderbolt, as confirmed with commands boltctl and ifconfig:
### pre-2 -> disconnects thunderbolt'
echo "1" | sudo tee /sys/devices/pci0000:00/0000:00:1c.4/remove > /dev/null
note: you must find the /sys/..... location from boltctl list and boltctl info at the first part of 'syspath'
### post-2 -> connect thunderbolt, after scanning pci bus
echo "1" | sudo tee /sys/bus/pci/rescan > /dev/null
tests connection before and after thunderbolt disconnect and connect
boltctl list # to find the uuid of the device
boltctl info <uuid> to find the 'syspath'
ifconfig
speedtest-cli
This is using the pci bus location DDDD:BB:DD.F listed in the command above to disconnect the thunderbolt, where the command to connect and disconnect the pci device is listed in the kernel.org link below. I also put a link an example at the superuser link::
https://superuser.com/questions/1046928/thunderbolt-hotplugging-in-ubuntu-linux https://www.kernel.org/doc/Documentation/ABI/testing/sysfs-bus-pci
The concept above is disconnecting the thunderbolt from the sysfs-bus-pci command, since boltctl doesn't have a command to disconnect yet, at least in linux kernel 5.11
By running ### pre-1 and ### pre-2 above before running systemctl suspend or systemctl hibernate, and then running ### post-1 and ### post-2 after suspend/hibernate, the ethernet now works perfectly after suspend/hibernate, and suspend/hibernate works each time as expected.
### pre-1
### post-1
I was previously getting errors for the ethernet driver that it couldn't change a power state.
These were the previous errors before using the solution with pre-1,pre-2,and post-1 and post-2 I just stated, and the 2 solutions using modprobe in /lib/systemd/system-sleep and /etc/systemd/system/ above by other answers were not working below for me, though in the below example I had commented the modprobe sections out after trying them.
Nov 06 16:23:25 mbp-ubu kernel: tg3 0000:3c:00.0: can't change power state from D3hot to D0 (config space inaccessible)
Nov 06 16:23:25 mbp-ubu kernel: tg3 0000:3c:00.0: phy probe failed, err -19
Nov 06 16:23:25 mbp-ubu kernel: tg3 0000:3c:00.0: invalid large VPD tag 7f at offset 0
Nov 06 16:23:25 mbp-ubu kernel: tg3 0000:3c:00.0: Problem fetching invariants of chip, aborting
Nov 06 18:04:29 mbp-ubu driver_tg3-refresh[7811]: Running suspend pre
Nov 06 18:04:29 mbp-ubu driver_tg3-refresh[7812]: now logging in pre
Nov 06 18:05:09 mbp-ubu driver_tg3-refresh[7835]: Running suspend post
Nov 06 18:05:09 mbp-ubu driver_tg3-refresh[7840]: now logging in post
Nov 06 18:05:09 mbp-ubu systemd[1]: Starting Fix tg3 ethernet driver on resume from suspend/hibernate...
Nov 06 18:05:09 mbp-ubu systemd[1]: fix-wake-ethernet-tg3.service: Succeeded.
Nov 06 18:05:09 mbp-ubu systemd[1]: Finished Fix tg3 ethernet driver on resume from suspend/hibernate.
The issue is with the power state of the ethernet and/or thunderbolt connection that can't be changed or changed in time, and the solution of disconnecting the thunderbolt from the linux /sys pci commands above and removing network manager led to a consistent solution for me, since it removes the thunderbolt and ethernet well before the suspend and hibernate take place, and you can create bash scripts to automate, or an alias in ~/.bashrc.
On Macbookpro with Ubuntu 20.04 LTS linux and an internet connection with a thunderbolt2 to
ethernet connection, where the thunderbolt to ethernet cable is causing problems with suspend/hibernate:
Before suspend/hibernate:
After suspend/hibernate:
I was able to develop a new systemd script at the same location as the original selected answer by Paulo Marcel Coelho Aragão, and confirmed that it works.
In this case, thunderbolt is disconnected, and then NetworkManager is turned off before suspend/hibernate, and after suspend/hibernate thunderbolt is connected and NetworkManager is turned on. This is so that suspend/hibernate is not interrupted or failed from an issue changing the power state of thunderbolt/ethernet from D0 to D3 or vice versa, causing the computer to reboot or require force reboot. I recently found that leaving NetworkManager on before suspend/hibernate can cause hibernate to reboot.
Below are the contents of /lib/systemd/system-sleep/pre-post_suspend-hibernate, and it has been tested to work very well, but you must alter the location of the disconnect pcie interface for thunderbolt as listed previously in this answer above from /sys/devices/pci0000\:00/0000\:00\:1c.4 to the location of your ethernet/thunderbolt interface, and also add /etc/netplan/99_config.yaml.
- Add /etc/netplan/99_config.yaml as listed above, modifying ens9
- Add /lib/systemd/system-sleep/pre-post_suspend-hibernate below, modifying: /sys/devices/pci0000\:00/0000\:00\:1c.4
#!/bin/bash
state=$1
action=$2
function log {
if [[ $state == pre ]]; then
log "following is ifconfig before attempt to disconnect thunderbolt:" &&
ifconfig 2>&1 | logger
log "disconnecting thunderbolt" &&
echo "1" | /usr/bin/tee /sys/devices/pci0000:00/0000:00:1c.4/remove > /dev/null
log "following is ifconfig after attempt to disconnect thunderbolt:" &&
log "stopping NetworkManager" &&
log "following is ifconfig after stopped NetworkManager:"
fi
log "following is ifconfig before attempt to connect thunderbolt:" &&
log "re-connecting thunderbolt" &&
echo "1" | /usr/bin/tee /sys/bus/pci/rescan > /dev/null
log "following is ifconfig after attempt to connect thunderbolt:" &&
sleep 1 && log "sleep 1" &&
log "starting NetworkManager" &&
log "following is ifconfig after started NetworkManager:" &&
fi
You can test this by looking at the logs in /var/log/syslog or journalctl where 'root' is chosen since
the script above in systemd is called from 'root'. 'pre-post' is part of the name of the
script above. You can add 'grep -e tg3 -e ens9' where tg3 is the name of the ethernet driver
and ens9 is the name of the thunderbolt interface, for this computer. This can all be tested with /sys/power/pm_test
set to "freezer", and then put /sys/power/pm_test back to "none" when you are done to get out of
test mode, where "freezer" is great for fast debugging and testing since it only freezes processes.
grep -e pre-post -e root /var/log/syslog | tail -70
journalctl | grep -e sudo | tail -35
journalctl | grep -e ens9 -e tg3 -e pre-post -e sudo | tail -120
lll /sys/devices/pci0000:00/0000:00:1c.4
more /sys/power/disk; more /sys/power/state; more /sys/power/pm_test
echo none | sudo tee /sys/power/pm_test
systemctl suspend
systemctl hibernate
journalctl is more complete than /var/log/syslog, since it has all of the logs, and you can find more about journalctl at: https://www.digitalocean.com/community/tutorials/how-to-use-journalctl-to-view-and-manipulate-systemd-logs
The following will create a new ovveride file at a location dependent on your machine, but in this case at: /etc/systemd/system/systemd-hibernate.service.d/override.conf
Install this fix to hibernate, with the following commands:
sudo apt install uswsusp
sudo systemctl edit systemd-hibernate.service
[Service]
ExecStart=
ExecStartPre=-/bin/run-parts -v -a pre /lib/systemd/system-sleep
ExecStart=/usr/sbin/s2disk
ExecStartPost=-/bin/run-parts -v --reverse -a post /lib/systemd/system-sleep
The following command should show you the systemd-hibernate.service file and the override file:
sudo systemctl cat systemd-hibernate.service
Update systemd, or reboot:
$ sudo systemctl daemon-reload
Now run
$ sudo systemctl hibernate
