Yesterday I upgraded for Ubuntu 16.10 to 17.04 and pulseaudio-equalizer is no longer working. This is similar to the question asked here:
Pulse audio equaliser that has presets?
The solution for that question, to use qpaeq, is not a good one for me because I use bluetooth speakers and qpaeq only seems to work on the internal speakers or the headphone jack (not bluetooth speakers)
I have completely removed and re-installed pulseaudio and pulseaudio-equalizer, but the equalizer isn't available in the launcher and I get "command not found" when I try to run it from the terminal.
I'm looking for a solution to use an equalizer with my bluetooth speakers. Either by getting pulseaudio-equalizer to work as it did in 16.10 or to get qpaeq to work with the bluetooth speakers.
I'm a bit of a novice with Ubuntu/Linux so any input is welcome.
Thanks.
terdon
  • 104,119
If this helps anyone,the FFT based equalizer has to be selected as the output device in the sound app in linux cinnamon. I could not understand why it stopped working. Slider controls had no effect.
Sal
The OP posted the following as an edit to their question. I am reproducing it as an answer.
I was able to fix my issue by force installing the version of pulseaudio-equalizer in the webupd8 ppa. Here's what I did:
1 - Install webupd8 ppa
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
2 - Using Synaptic Package Manager I searched for and selected "pulseaudio-equalizer". From the "Package" menu I chose "Force Version" then I selected 2.7.0.2-5~webupd8~xenial0 . This also installs a bunch of dependencies.
Now it works just as before. I guess this is technically a "downgrade" but I'll gladly take a functional downgrade over a non-functioning upgrade.
terdon
  • 104,119
-1
Could give a try to following solution
