I am running Lubuntu 17.10. Loading qpaeg with:
pactl unload-module module-equalizer-sink
pactl unload-module module-dbus-protocol
pactl load-module module-equalizer-sink
pactl load-module module-dbus-protocol
qpaeq
I get no module load errors and the qpaeq pops up correctly. When I change any of the sound levels it has no effect on sound output, and on the console above I get,
Traceback (most recent call last):
 File "/usr/bin/qpaeq", line 450, in write_coefficient
    self.filter_state.seed()
  File "/usr/bin/qpaeq", line 511, in seed
    self.sink.SeedFilter(self.channel,self.filter_frequencies,self.coefficients,self.preamp)
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.InvalidArgs: xs must be monotonic and 0<=x<=16384
Does anyone have any helpful suggestions? I have tried the many suggestions I have seen on the web, but nothing works.
Is there a way to revert to an older version that works? I tried
pulseaudio-equalizer not working
but after following the procedure I was not offered the old version by synaptic.
I have resolved this. Because it happened inadvertently the details are incomplete, but there it is.
I had upgraded to 18.04 as per the auto recommend. The problem persisted with the same behaviour, but a slightly different error message.
I installed pulseeffects. Following another Ubuntu post, pulse audio equaliser not working in ubuntu 18.04
So as root:
wget https://launchpad.net/~yunnxx/+archive/ubuntu/gnome3/+files/pulseeffects_1.313entornosgnulinuxenial-1ubuntu1_amd64.deb
dpkg -i pulseeffects_1.313entornosgnulinuxenial-1ubuntu1_amd64.deb
The dpkg install failed lacking python-cairo, so
apt install python-cairo
That failed also, but suggested:
apt --fix-broken install
which installed python-cairo and a various other stuff (that is where I lack detail here - I didn't save the list).
Then I re-tried the dpkg install and it worked.
I now had pulseeffects installed and working.
I tried pulseaudio-equalizer again out of interest and it now worked. I guess that python-cairo or the stuff that got installed with it fixed the problem.
BTW I would recommend pulseeffects. The up/down keys can be used to make precise 1Db changes in each frequency range bar, and the 'tone' facility has enabled calibrating a 'flat' response from my amp & speakers. It revealed a massive hole in the response at 250cps. It all sounds so much better now.
