How can I disable systemd-resolved in Ubuntu 17.04?
Disabling it with systemctl disable didn't work, the service seems to be restarted (by Networkmanager?)
This method works on the Ubuntu releases 17.04 (Zesty), 17.10 (Artful), 18.04 (Bionic), 18.10 (Cosmic), 19.04 (Disco) and 20.04 (Focal):
Disable and stop the systemd-resolved service:
sudo systemctl disable systemd-resolved
sudo systemctl stop systemd-resolved
Then put the following line in the [main] section of your /etc/NetworkManager/NetworkManager.conf:
dns=default
Delete the symlink /etc/resolv.conf
rm /etc/resolv.conf
Restart NetworkManager
sudo systemctl restart NetworkManager
Also be aware that disabling systemd-resolvd might break name resolution in VPN for some users. See this bug on launchpad (Thanks, Vincent).
If you are using Ubuntu 18.04 Server (or Ubuntu 20.04 Server), none of these answers apply. The one by user2427436 comes closest.
The issue is that systemd-resolved is/runs a stub resolver, and I just need to completely disable that (per the question). I need to do this because Zimbra 8.8.15 (FOSS) comes with its own integrated resolver (unbound).
In my situation I am starting from a stock (naive) install of server 18.04, with minimal options on bare metal (well, actually a VM).
so here's the recipe:
vi /etc/systemd/resolved.conf
edit line #DNSStubListener=yes
to be DNSStubListener=no
systemctl status systemd-resolved
rm /etc/resolv.conf
reboot to test...
This is what /etc/systemd/resolved.conf looks like now:
# See resolved.conf(5) for details
[Resolve]
#DNS=
#FallbackDNS=
#Domains=
#LLMNR=no
#MulticastDNS=no
#DNSSEC=no
#Cache=yes
DNSStubListener=no
that's all it took.
Feel free to install any other resolver you want after this.
I've recently upgraded to (k)Ubuntu 17.04 and I also stumbled upon the change to systemd.
My setup is fairly typical I think, in that I have a DNS provider in my broadband HUB and this is my primary source of information for all the devices on my network (of which I have a few).
There is some beauty in systemd, it's not all bad but what is really bad is the documentation, the lack of communication from the Ubuntu team and the gung-ho "let's just change it despite it breaks for everyone" mentality.
The solution for me after tearing some hair out was to edit /etc/systemd/resolved.conf:
[Resolve]
DNS=192.168.1.254 # <-- change to your router address
#FallbackDNS=8.8.8.8 8.8.4.4 2001:4860:4860::8888 2001:4860:4860::8844
Domains=lan # <-- change to your localdomain name (maybe .local)
#LLMNR=yes <-- I dabbled with this for a while but it doesn't matter
#DNSSEC=no
#Cache=yes
#DNSStubListener=udp
After not understanding why this wouldn't work I figured out that what was also needed was to switch /etc/resolv.conf to the one provided by systemd. This isn't the case in an out-of-a-box install (for reasons unknown to me).
sudo ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf
The local DNS server is then not used and all DNS requests are sent to my HUB.
I think this is a much better solution than cutting out and putting in some other solution since systemd-resolv is now the default onwards.
A related problem btw is that the /etc/nsswitch.conf is neutered.
It should read:
hosts: files mdns4_minimal dns [NOTFOUND=return] resolve [!UNAVAIL=return] dns
This is a confusing configuration since [NOTFOUND=return] means processing ends there. The entries after it will never be used.
If you are having leaks issues with your VPN and can't figure out how to set up systemd (like me) you can remove it in the way described in the first answer but don't add the dns=default line because it will activate the nameserver 127.0.0.1.
To set the router as dns, create the file "tail" in your /etc/resolvconf/resolv.conf.d/
folder adding the line nameserver 192.168.1.1
do ln -sf /var/run/resolved/resolv.conf /etc/resolv.confif you had messed up with this file.
I feel compelled to add this excellent answer appearing on a dupe, it covers the case where you want the minimal setup of ifupdown + dhclient + resolvconf (yes this is still possible in 2021 in Ubuntu Focal).
This use case isn't covered by the other answers. Maybe we should strive to provide non-systemd-resolved setups for most of the different combinations we could want in our networking stack (netplan-based, networkmanager-based, wicd, and so on).
