I am trying to set up dnsmasq as an address resolver on an Ubuntu 18.10.
So far I disabled systemd-resolved as the default resolver and brought dnsmasq in. Running netstat -tulpn shows the following:
> sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      31609/dnsmasq
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      561/sshd
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      4614/openvpn
tcp6       0      0 :::53                   :::*                    LISTEN      31609/dnsmasq
tcp6       0      0 :::22                   :::*                    LISTEN      561/sshd
udp        0      0 0.0.0.0:53              0.0.0.0:*                           31609/dnsmasq
udp        0      0 XXX.XXX.XX.XX:YY        0.0.0.0:*                           440/systemd-network
udp6       0      0 :::53                   :::*                                31609/dnsmasq
I think this is fine so far, as now dnsmasq is listening on port 53.
My /etc/resolv.conf looks like this:
nameserver 127.0.0.1
nameserver 127.0.1.1
nameserver 127.0.0.53
I am not sure about the second line, but I think this should be fine so far, too.
Nevertheless, when I try to run dig, ping or whatever, the connection always times out:
> dig askubuntu.com
; <<>> DiG 9.11.4-3ubuntu5-Ubuntu <<>> askubuntu.com
;; global options: +cmd
;; connection timed out; no servers could be reached
Where did I do something wrong, so I broke those functions?
flomei
  • 113
systemd-resolved is still running, as I see 127.0.0.53 in your /etc/resolv.conf.
If dnsmasq was running, it would show 127.0.0.1.
When you run both together, they tend to step on each others toes.
To run dnsmsaq, and to disable the DNS functionality of systemd-resolved, you need to edit /etc/systemd/resolved.conf and...
change:
#DNSStubListener=yes
to:
DNSStubListener=no
then reboot, recheck /etc/resolv.conf and you should see 127.0.0.1.
postnote: do NOT manually edit /etc/resolv.conf.
heynnema
  • 73,649
