16
I've decided systemd-resolved is irretrievably broken garbage and I'd like to replace. I've got my own local DNS server at 192.168.1.2 I'd like. I'd also like to connect to a VPN with NetExtender that gives me a DNS server for a .local domain. I would like these two things to work together, what can I do?
gct
  • 261
The answer by Gannet is incorrect. If you want to use plain ifupdown like in earlier releases, without netplan or NetworkManager (e.g. on a server), with dhcp, you need to do this:
systemctl disable systemd-resolved.service
systemctl stop systemd-resolved.service
check if resolv.conf is pointing to resolvconf
ls -la /etc/resolv.conf
lrwxrwxrwx 1 root root 27 May 7 16:15 /etc/resolv.conf -> /run/resolvconf/resolv.conf
if not, delete /etc/resolv.conf and symlink it like this:
rm /etc/resolv.conf ln -s /run/resolvconf/resolv.conf /etc/resolv.conf
this will remove the resolved stub resolver entry from resolv.conf
resolvconf -d systemd-resolved
fix dhclient scripts
chmod -x /etc/dhcp/dhclient-enter-hooks.d/resolved chmod +x /etc/dhcp/dhclient-enter-hooks.d/resolvconf
on my machine just chmod -x wasn't enough, I had to move the resolved script somewhere else
mv /etc/dhcp/dhclient-enter-hooks.d/resolved ~
ifdown/ifup your interface to regenerate resolv.conf (or systemctl restart ifup@eth0)
ifdown eth0; ifup eth0
check /etc/resolv.conf has the right settings
jjakob
  • 69
You can always disable your systemd-resolved by
command. And run:
sudo rm /etc/resolv.conf && sudo ln -s /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf
to use /etc/resolv.conf config as it was earlier in previous ubuntu versions.
Gannet
  • 521
Both answers can lead to issues with VPN. Also, if it's desired to keep NetworkManager, the following can be done:
Unlink resolvconf if this is linked to resolvectl:
ls -lah $(which resolvconf)
If resolveconf is linked to resolvectl, like the following:
/usr/local/bin/resolvconf -> /usr/bin/resolvectl
We need to unlink it:
sudo unlink /usr/local/bin/resolvconf
Now, install resolvconf because most VPN uses it:
sudo apt-get install resolvconf
set dns=none to [main] section in /etc/NetworkManager/NetworkManager.conf:
[main]
dns=none
Now, we have two options here:
  • Manually set DNSes system-wide
  • Use resolvconf to set DNS:
Place desired DNS servers as nameserver in /etc/resolv.conf:
nameserver 8.8.8.8
nameserver 8.8.4.4
nameserver 1.1.1.1
This is preferred way if you're using a VPN with specific DNS servers configured through it
sudo ln -sfn /run/resolvconf/resolv.conf /etc/resolv.conf
meetnick
  • 450
