Hi all i have been running Ubuntu Server 16.04 on my headless server for several months without issue, recently i took the server offline for some routine cleaning & replaced a PSU, upon booting it back up for some reason the server has no outgoing internet connection here are the results of some tests
ben@ubuntu:~$ ping -c5 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=55 time=23.7 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=55 time=23.5 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=55 time=23.6 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=55 time=23.3 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=55 time=29.9 ms
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 23.396/24.844/29.937/2.556 ms
trying to ping a hostname
ben@ubuntu:~$ ping www.cisco.com -c 1 -s 1472 -M do
ping: unknown host www.cisco.com
ben@ubuntu:~$
Ping www.cisco.com via IP adress
ben@ubuntu:~$ ping -c5 23.204.15.199
PING 23.204.15.199 (23.204.15.199) 56(84) bytes of data.
64 bytes from 23.204.15.199: icmp_seq=1 ttl=46 time=229 ms
64 bytes from 23.204.15.199: icmp_seq=2 ttl=46 time=229 ms
64 bytes from 23.204.15.199: icmp_seq=3 ttl=46 time=239 ms
64 bytes from 23.204.15.199: icmp_seq=4 ttl=46 time=229 ms
64 bytes from 23.204.15.199: icmp_seq=5 ttl=46 time=229 ms
contents of resolv.conf
# This file is managed by man:systemd-resolved(8). Do not edit.
# 127.0.0.53 is the systemd-resolved stub resolver.
# run "systemd-resolve --status" to see details about the actual nameservers.
nameserver 127.0.0.53
contents of if config
ben@ubuntu:~$ ifconfig
enp8s0 Link encap:Ethernet HWaddr 00:1e:67:51:8e:8c
inet addr:192.168.0.251 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::21e:67ff:fe51:8e8c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1492 Metric:1
RX packets:20820 errors:0 dropped:50 overruns:0 frame:0
TX packets:16017 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4243433 (4.2 MB) TX bytes:4596251 (4.5 MB)
Interrupt:16 Memory:c2300000-c2320000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:18434 errors:0 dropped:0 overruns:0 frame:0
TX packets:18434 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2225861 (2.2 MB) TX bytes:2225861 (2.2 MB)
contents of /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto enp8s0
iface enp8s0 inet static
address 192.168.0.251
netmask 255.255.255.0
gateway 192.168.0.1
dns-nameservers 8.8.8.8 8.8.4.4
contents of /etc/hosts
127.0.0.1 localhost
127.0.1.1 ubuntu
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
I can SSH into the box from my mobile phone using 4G connection (outside of my local network)
Any ideas, system has been running great now all of a sudden no internet access,
Thank You
-Ben
