26
I have a Dell XPS 15 9550. I've been running Ubuntu 16.10 on it for four months with no dramas.
Two days ago, I upgraded to Ubuntu 17.04. About an hour after upgrading, my hard-drive remounted into read-only mode. When I jumped to a tty screen, this appeared:
[ 746.341551] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #525023: comm NetworkManager: reading directory iblock 0
[ 746.343318] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #524289: comm pool: reading directory iblock 0
[ 746.356125] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #11272213: comm systemd-udevd: reading directory iblock 0
[ 746.356139] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #11272210: comm systemd-udevd: reading directory iblock 0
[ 746.356332] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #11272193: comm systemd-udevd: reading directory iblock 0
[ 746.356338] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #11272825: comm systemd-udevd: reading directory iblock 0
[ 746.356400] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #11272210: comm systemd-udevd: reading directory iblock 0
[ 746.474632] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #524539: comm unity-settings-: reading directory iblock 0
[ 746.992814] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #5506108: comm BrowserBlocking: reading directory iblock 0
[ 746.304451] EXT4-fs error (device nvme0n1p7): ext4_find_entry:1463: inode #5506117: comm BrowserBlocking: reading directory iblock 0
Here's what fdisk -l shows:
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 3CD27380-DAC8-48DC-910A-D084CE857DA3
Device             Start        End   Sectors   Size Type
/dev/nvme0n1p1      2048    1026047   1024000   500M EFI System
/dev/nvme0n1p2   1026048    1288191    262144   128M Microsoft reserved
/dev/nvme0n1p3   1288192  487948287 486660096 232.1G Microsoft basic data
/dev/nvme0n1p4 972302336  973223935    921600   450M Windows recovery environmen
/dev/nvme0n1p5 973223936  998094847  24870912  11.9G Windows recovery environmen
/dev/nvme0n1p6 998094848 1000204287   2109440     1G Windows recovery environmen
/dev/nvme0n1p7 487948288  939046911 451098624 215.1G Linux filesystem
/dev/nvme0n1p8 939046912  972302335  33255424  15.9G Linux swap
Partition table entries are not in disk order.
I rebooted, and continued to get the error around once an hour. So I reinstalled Ubuntu 17.04 from scratch. However I am still getting the same issue.
I tried running fsck by creating a /forcefsck file (I created a wrapper shell script that adds the -v flag and outputs stdout to a file). Here's the result:
fsck.fat 4.0 (2016-05-06)
Checking we can access the last sector of the filesystem
Boot sector contents:
System ID "MSDOS5.0"
Media byte 0xf8 (hard disk)
       512 bytes per logical sector
      4096 bytes per cluster
      6206 reserved sectors
First FAT starts at byte 3177472 (sector 6206)
         2 FATs, 32 bit entries
    508416 bytes per FAT (= 993 sectors)
Root directory start at cluster 2 (arbitrary size)
Data area starts at byte 4194304 (sector 8192)
    126976 data clusters (520093696 bytes)
63 sectors/track, 255 heads
      2048 hidden sectors
   1024000 sectors total
Reclaiming unconnected clusters.
Checking free cluster summary.
/dev/nvme0n1p1: 212 files, 15526/126976 clusters
I tried booting from a live USB and running e2fsck -p /dev/nvme0n1p7 as suggested here (https://askubuntu.com/a/768813/679041). It didn't give any errors.
I also tried to run smartctl -t long /dev/nvme0n1p7 however the results seem to indicate that the tool doesn't work with my particular SSD:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.10.0-19-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       PM951 NVMe SAMSUNG 512GB
Serial Number:                      S29PNX0H611013
Firmware Version:                   BXV77D0Q
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Controller ID:                      1
Number of Namespaces:               1
Namespace 1 Size/Capacity:          512,110,190,592 [512 GB]
Namespace 1 Utilization:            254,982,533,120 [254 GB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Mon Apr 17 17:45:48 2017 AEST
Firmware Updates (0x06):            3 Slots
Optional Admin Commands (0x0017):   Security Format Frmw_DL *Other*
Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Maximum Data Transfer Size:         32 Pages
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     6.00W       -        -    0  0  0  0        5       5
 1 +     4.20W       -        -    1  1  1  1       30      30
 2 +     3.10W       -        -    2  2  2  2      100     100
 3 -   0.0700W       -        -    3  3  3  3      500    5000
 4 -   0.0050W       -        -    4  4  4  4     2000   22000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
Read NVMe SMART/Health Information failed: NVMe Status 0x2002
Any idea of why this issue might be occuring and how I might solve it? Thanks! :)
Ben B
  • 681
5 Answers5
30
As pointed out in a comment by Elder Geek, this is due to a known bug.
From the bug report:
APST support just landed in the latest Zesty kernel (4.10.0-14.16) as part of https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1664602. That patch has a quirk for certain 256GB Samsung drives found in Dell laptops that do not behave well when APST is enabled. I am experiencing the same symptoms with the same model laptop except with a 512GB Samsung. Prior to manually disabling APST the drive would die and system would go down in flames with I/O errors within 20 to 40 minutes of boot.
Until a proper fix is implemented, a workaround is suggested, which involves adding a kernel parameter:
Please try nvme_core.default_ps_max_latency_us=5500, if the issue persists, please try nvme_core.default_ps_max_latency_us=200.
To add a kernel boot parameter, edit the configuration file for GRUB:
sudo nano /etc/default/grub
Find the line beginning GRUB_CMDLINE_LINUX_DEFAULT and add the boot parameter to the others already between the quotes. For example, in this case you will probably end up with
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvme_core.default_ps_max_latency_us=5500"
Save the file and exit, then to make the change effective, run
sudo update-grub
Elder Geek
  • 36,752
Ben B
  • 681
First, I'd visit the Samsung support web site and assure that you've got the latest firmware installed for your model SSD.
Then, your fsck didn't make a whole lot of sense, so do it this way...
To check the file system on your Ubuntu partition...
  • boot to the GRUB menu
  • choose Advanced Options
  • choose Recovery mode
  • choose Root access
  • at the # prompt, type sudo fsck -f /
  • repeat the fsck command if there were errors
  • type reboot
heynnema
  • 73,649
One possible workaround to the known bug I mentioned, which I'm unable to test, as I don't have the NVMe hardware in question, would be to try booting the current mainline daily kernel build package for your architecture available here.
Wait! before you dash off to try this, I must stress that unless you are certain you know exactly what you are doing and how to recover from unintended consequences it's highly recommended to backup.
If you don't know what you are doing and do have a current backup you can find more information on building your kernel here.
Note: In case you skimmed the first sentence, this answer is based on research, not testing. If it breaks, restore your backup.
Elder Geek
  • 36,752
every time I open my laptop and try this command line. I have done this several times. and now my ext4-fs-error problem is solved.
and change GRUB_CMDLINE_LINUX_DEFAULT= to
then save and exit. and write this command
sudo update-grub
thanks to Ben B, for 1st comment. I get this command line from his answer (EXT4-fs error after Ubuntu 17.04 upgrade) .
I observed a similar error on a Lenovo ThinkPad P570 and after a fresh installation of Ubuntu 20.04 and Ubuntu 21.04.
It could be resolved by switching off the "UEFI Secure Boot" setting in the BIOS which initially was set on.
