After installing Ubuntu 17.04, my system started to randomly go into read-only mode. I am not sure whether the problem is hardware related, which is why I am seeking help here. The following is the output of running dmesg:
[  153.980788] systemd[1]: snapd.refresh.timer: Adding 3h 28min 7.902429s random time.
[  153.980793] systemd[1]: snapd.refresh.timer: Adding 2h 31min 56.416202s random time.
[  153.981010] systemd[1]: apt-daily.timer: Adding 7h 14min 15.923815s random time.
[  180.145338] systemd[1]: snapd.refresh.timer: Adding 1h 19min 56.064983s random time.
[  180.145343] systemd[1]: snapd.refresh.timer: Adding 2h 19min 4.310984s random time.
[  180.145582] systemd[1]: apt-daily.timer: Adding 1h 7min 52.267530s random time.
[  316.563746] EXT4-fs error (device nvme0n1p4): ext4_validate_block_bitmap:384: comm kworker/u16:1: bg 259: bad block bitmap checksum
[  316.649798] Aborting journal on device nvme0n1p4-8.
[  316.740313] EXT4-fs (nvme0n1p4): Remounting filesystem read-only
And the output of sudo smartctl -a /dev/nvme0n1 | less:
=== START OF INFORMATION SECTION ===
Model Number:                       INTEL SSDPEKKW512G7
Serial Number:                      BTPY64530SB1512F
Firmware Version:                   PSF100C
PCI Vendor/Subsystem ID:            0x8086
IEEE OUI Identifier:                0x5cd2e4
Controller ID:                      1
Number of Namespaces:               1
Namespace 1 Size/Capacity:          512,110,190,592 [512 GB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Sun May  7 20:14:46 2017 UTC
Firmware Updates (0x12):            1 Slot, no Reset required
Optional Admin Commands (0x0006):   Format Frmw_DL
Optional NVM Commands (0x001e):     Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Maximum Data Transfer Size:         32 Pages
Warning  Comp. Temp. Threshold:     70 Celsius
Critical Comp. Temp. Threshold:     80 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     9.00W       -        -    0  0  0  0        5       5
 1 +     4.60W       -        -    1  1  1  1       30      30
 2 +     3.80W       -        -    2  2  2  2       30      30
 3 -   0.0700W       -        -    3  3  3  3    10000     300
 4 -   0.0050W       -        -    4  4  4  4     2000   10000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0x1)
Critical Warning:                   0x00
Temperature:                        29 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    1,872,872 [958 GB]
Data Units Written:                 1,943,407 [995 GB]
Host Read Commands:                 25,786,657
Host Write Commands:                23,483,001
Controller Busy Time:               386
Power Cycles:                       310
Power On Hours:                     1,581
Unsafe Shutdowns:                   71
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Error Information (NVMe Log 0x01, max 64 entries)
No Errors Logged
I've fixed the SSD a couple of times already by booting from a live-USB and running:
sudo dumpe2fs /dev/nvme0n1p4 | grep superblock #just in case
sudo fsck -b 32768 -y /dev/nvme0n1p4
Example output:
/dev/nvme0n1p4: ***** FILE SYSTEM WAS MODIFIED *****
/dev/nvme0n1p4: 367181/15630336 files (0.3% non-contiguous), 9061081/62520064 blocks
The problem, however, persists.
Don't know if related, but from the installation USB, gparted pops-up the following warning: "The driver descriptor says the physical block size is 2048 bytes, but Linux says it is 512 bytes.".
Any help would be greatly appreciated. Thanks!
Edit: For reference, my drive is an Intel SSD 600p .
martin
  • 103
Check the Intel SSD firmware by downloading the IntelĀ® SSD Firmware Update Tool at https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool?product=35125
And, if this is a Dell computer, search here on Ask Ubuntu for "dell ssd" and see the kernel parameter fix there. And although it refers to Samsung SSD's, read the accepted answer at EXT4-fs error after Ubuntu 17.04 upgrade
heynnema
  • 73,649
