54
After the installation of any programs I get the following error
Processing triggers for libc-bin (2.23-0ubuntu7) ...
/sbin/ldconfig.real: /usr/lib/nvidia-375/libEGL.so.1 is not a symbolic link
/sbin/ldconfig.real: /usr/lib32/nvidia-375/libEGL.so.1 is not a symbolic link
What is this error and how can I solve it?
Dante
  • 1,949
This is an issue which has affected many users and is reported as a bug at Launchpad.
There appears to be a conflict between different versions of libEGL.
To get rid of these warning, create the following symlinks (but first read the warning bellow):
sudo mv /usr/lib/nvidia-375/libEGL.so.1 /usr/lib/nvidia-375/libEGL.so.1.org
sudo mv /usr/lib32/nvidia-375/libEGL.so.1 /usr/lib32/nvidia-375/libEGL.so.1.org
sudo ln -s /usr/lib/nvidia-375/libEGL.so.375.39 /usr/lib/nvidia-375/libEGL.so.1
sudo ln -s /usr/lib32/nvidia-375/libEGL.so.375.39 /usr/lib32/nvidia-375/libEGL.so.1
Warning: There is no need to change your system. If after reboot you can not start the graphical interface you can solve by:
1. Login into a terminal;
2. Run sudo dpkg-reconfigure nvidia*
desgua
  • 33,215
Noisy_Botnet
  • 1,609
  • 13
  • 15
11
The following is an easy-to-use version of Noisy_Botnet's solution. It facilitates repeating the process for any update.
#! /bin/sh
# find the file in /usr/lib
LIBEGL=`find /usr/lib/nvidia* -name libEGL.so.\* | egrep "[0-9][0-9]*\.[0-9][0-9]*$"`
LIBEGL_LINK=`echo $LIBEGL | sed 's/[0-9][0-9]*\.[0-9][0-9]*$/1/'`
printf "\n\nThe following commands will be executed:\n+++++++++++++++++++++++++++++++++++++++\n"
printf "mv $LIBEGL_LINK ${LIBEGL_LINK}.orig\nln -s $LIBEGL $LIBEGL_LINK\n\n"
while true; do
    read -p "Do you wish to perform these commands?  " yn
    case $yn in
        [Yy]* ) mv $LIBEGL_LINK ${LIBEGL_LINK}.orig; ln -s $LIBEGL $LIBEGL_LINK ; break;;
        [Nn]* ) break;;
        * ) echo "Please answer yes or no.";;
    esac
done
# find the file in /usr/lib32
LIBEGL=`find /usr/lib32/nvidia* -name libEGL.so.\* | egrep "[0-9][0-9]*\.[0-9][0-9]*$"`
while true; do
    case $yn in
        [Nn]* ) break;;
    esac
done
muru
  • 207,228
did you upgrade without update first? I had the same message, I updated, upgraded and the message was gone
sudo apt-get update
sudo apt-get upgrade
I had the same issue and ended up getting through it; it had worked before. I have Cuda 8.0 and Tensorflow 1.3 on Ubuntu 16.04.
This is how I resolved the issue. First,
sudo apt-get update
Then,
sudo ldconfig /usr/local/cuda/lib64
It works now. The execution order matters.
