I recently upgraded my computer from 17.10 to 18.04. This involved an upgrade of the nvidia graphics driver from nvidia-384 to nvidia-driver-390. However, I noticed that nvidia-384 was still installed after the upgrade, and strangely seems to depend on nvidia-driver-390.
The problem:
Whenever I run apt upgrade, I get errors that look like
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf: No such file or directory
When I look for /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf, I can see that it is a broken symlink to /etc/alternatives/i386-linux-gnu_egl_conf, which itself is a broken symlink to /usr/lib/nvidia-384-prime/alt_ld.so.conf. The entire directory /usr/lib/nvidia-384-prime does not even exist.
What I have already tried:
I tried purging all nvidia packages using:
sudo apt purge --autoremove nvidia*
I then rebooted (and checked that nouveau drivers were loaded), reinstalled nvidia-driver-390, and rebooted again.
Now I no longer have the nvidia-384 package (only nvidia-driver-390 which seems to be working normally), but the broken symlinks and error messages are still there. Moreover, there is a directory /usr/lib/nvidia-384, but I assume that should be gone since I do not have nvidia-384.
My question:
Can/should I just remove the broken symlinks to stop these error messages? Or is there some other (cleaner) way which would remove these, as well as any other extraneous files/directories/links that may be on my computer (like the /usr/lib/nvidia-384 directory)?
Thanks in advance!
EDIT: I just tried renaming /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf to /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf.bak to "remove" it (in the eyes of ldconfig)...it seems to "resolve" the issue in that I no longer get ldconfig errors. But I still have the extraneous nvidia-384 directory which I do not know what to do with...again not sure if there is a clean way to remove all of the unnecessary files related to this.
Had more or less the same problem after an update (ldconfig error). The following command deleted all invalid links:
sudo update-alternatives --config i386-linux-gnu_egl_conf
nspo
  • 151
