19
Since I installed Ubuntu 16.04 my laptop (HP Probook 450 G2) has issues waking up from suspend. Rarely it manages to properly wake up from suspend, but mostly the screen either stays black or it turns on, and completely freezes after 2 or 3 seconds, followed by a bit louder fan activity in both cases. I cannot switch to a tty shell, or do anything else apart from killing the power by holding the power button.
I tried following different solutions such as disabling USB Legacy, adding acpi_backlight=vendor acpi_osi='!Windows 2013' acpi_osi='!Windows 2012' to GRUB_CMDLINE_LINUX_DEFAULT, but nothing worked.
I switched to Linux Mint yesterday just to test if I have an issue there, but it still persists. Here is the output of /var/log/kern.log which shows the last messages from my previous session.
Feb 13 09:51:55 hamza-PC kernel: [  913.345833] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.4773] manager: sleep requested (sleeping: no  enabled: yes)
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.4774] manager: sleeping...
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.4774] device (wlo1): state change: activated -> unmanaged (reason 'sleeping') [100 10 37]
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.4969] dhcp4 (wlo1): canceled DHCP transaction, DHCP client pid 1440
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.4970] dhcp4 (wlo1): state changed bound -> done
Feb 13 09:52:22 hamza-PC kernel: [  940.019586] wlo1: deauthenticating from b4:75:0e:ce:22:bb by local choice (Reason: 3=DEAUTH_LEAVING)
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.5125] dns-mgr: Writing DNS information to /sbin/resolvconf
Feb 13 09:52:22 hamza-PC kernel: [  940.034017] cfg80211: World regulatory domain updated:
Feb 13 09:52:22 hamza-PC kernel: [  940.034019] cfg80211:  DFS Master region: unset
Feb 13 09:52:22 hamza-PC kernel: [  940.034020] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Feb 13 09:52:22 hamza-PC kernel: [  940.034022] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 13 09:52:22 hamza-PC kernel: [  940.034024] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 13 09:52:22 hamza-PC kernel: [  940.034025] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Feb 13 09:52:22 hamza-PC kernel: [  940.034026] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Feb 13 09:52:22 hamza-PC kernel: [  940.034027] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Feb 13 09:52:22 hamza-PC kernel: [  940.034028] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Feb 13 09:52:22 hamza-PC kernel: [  940.034029] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Feb 13 09:52:22 hamza-PC kernel: [  940.034030] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Feb 13 09:52:22 hamza-PC NetworkManager[1004]: <info>  [1486975942.5423] manager: NetworkManager state is now ASLEEP
Feb 13 09:52:26 hamza-PC kernel: [  943.880782] i915 0000:00:02.0: BAR 6: [??? 0x00000000 flags 0x2] has bogus alignment
Feb 13 09:52:27 hamza-PC kernel: [  944.885059] i915 0000:00:02.0: BAR 6: [??? 0x00000000 flags 0x2] has bogus alignment
Also
uname -a
Linux hamza-PC 4.4.0-62-generic #83-Ubuntu SMP Wed Jan 18 14:10:15 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Any info would be helpful, thank you!
tepsijash
  • 381
7 Answers7
10
I have a 4.19 kernel and Nvidia driver version 390. I changed gdm to lightdm.
sudo apt install lightdm
Problem is solved now.
Fabby
  • 35,017
After using Ubuntu 16.04 LTS for a few days and everything was OK, I started to experience this freeze on suspend/sleep. I reinstalled the lightdm display manager and the problem didn't go away. I had similar logs to yours, but no hard errors.
What solved the problem for me was changing the default X.org video driver to the NVidia one.
This is located in Settings -> Software & Updates -> Additional Drivers
There I had the following option selected.
'Using X.org X server - Nouveau display driver...'
After changing it to:
Using NVidia binary driver ... (proprietary, tested)
Restart and everything is fine since then :)
luben
  • 131
I have had the same problem with Ubuntu 20.04 since installing some time ago - freezing on going into suspend - could only be dealt with by holding down the power-button for some six seconds or so. Tried all manner of suggestions - including those given above - but nothing worked, UNTIL I used the "Software & Updates" app to upgrade and, Hey Presto, all fixed!
Hope it works for you too.
Duncan
  • 1,113
Disable the "Ubuntu Dock" gnome shell extension:
gnome-extensions disable ubuntu-dock@ubuntu.com
zx485
  • 2,865
Open /etc/systemd/logind.conf using editor like Vim, gedit:
sudo gedit /etc/systemd/logind.conf
You will see all these options:
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#HandlePowerKey=poweroff
#HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
#HandleLidSwitch=suspend
#HandleLidSwitchDocked=ignore
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=yes
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RemoveIPC=yes
#UserTasksMax=12288
Just change these entries value to suspend and all will work fine:
HandleLidSwitchDocked=suspend
If still not fixed :
HandleHibernateKey=suspend
Check this article from itsfoss
Here is one method which helped me.
Edit grub configuration,
sudoedit /etc/default/grub
Change
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="text"
Then do
sudo update-grub
and reboot your computer.
pomsky
  • 70,557
Yukai
Temporary Solution | Stuck On The Logon Screen | Even After Many Restarts
If you still find yourself stuck on the logon screen even after the hard restart then follow these steps to get out of this...
  • Restart your system : Press & hold the power button for 5-10 seconds
  • Start the system in recovery mode by selecting "Advance Option for Ubuntu"
  • Select the first options that ends with "(recovery)"
  • Choose "root drop to root shell prompt" option and hint ENTER Key (twice)
  • Execute the following commands:
sudo dpkg --configure -a
sudo prime-select intel
sudo reboot
Note: : This would work only if you're using a system that has two graphics cards (such as nvidia+intel or intel+amd) and the non-intel one is configured as the primary one.
