10
Hi everyone I just installed Ubuntu 22.04, every time I suspend or lock my screen there is a black screen and I have to force shutdown.
I have NVIDIA 940MX
I have tried all the options on the Internet to downgrade the version from 510 to 470,390 , I tried to reconfigure the grub and I changed gdm to lightdm. Nothing worked out I tried those solutions:
  1. System freeze after suspend
  2. https://forums.developer.nvidia.com/t/solved-suspend-resuming-and-wakeup-with-nvidia370-28/45282
  3. how to solve black screen after suspension with Ubuntu 22.04 LTS?
I've been trying for almost 2 days nothing is working can someone please help me and guide me to solve this problem
I really appreciate any help you can provide.
6 Answers6
Solution that worked for me:
sudo systemctl stop nvidia-suspend.service
sudo systemctl stop nvidia-hibernate.service
sudo systemctl stop nvidia-resume.service
sudo systemctl disable nvidia-suspend.service sudo systemctl disable nvidia-hibernate.service sudo systemctl disable nvidia-resume.service
sudo rm /lib/systemd/system-sleep/nvidia
Detailed answer: how to solve black screen after suspension with Ubuntu 22.04 LTS?
xDrd
  • 101
Did you try to disable nvidia's services in systemctl?
To display a list of all services from nvidia:
systemctl list-unit-files | grep nvidia
I have this output:
nvidia-hibernate.service disabled enabled
nvidia-persistenced.service static -
nvidia-resume.service disabled enabled
nvidia-suspend.service disabled enabled
where first column is the name of the service, second column is the current state and the last one is the vendor's preset.
If those services are enabled you could try to disable them:
I had a similar issue, my HTPC does not suspend or lock, I just turn off the TV when I'm not watching. Each morning I would find the black screen and have to force shutdown (or you can get a shell and sudo systemctl restart gdm).
In the end I have worked around this problem and am very happy, here's what I did:
sudo apt install ubuntu-mate-desktop -y
That replaces gdm with lightdm (you should make it your default when asked during setup).
My setup:
  • Ubuntu 22.04
  • Nvidia GTX1650
  • Nvidia driver: nvidia-driver-515 (from PPA)
Beoski
  • 29
  1. Have you tried removing nvidia drivers and then checking if the issue persists?
  2. Could you paste the output of nvidia-smi?
  3. Have you tried by reinstalling the drivers?
I would install a suitable version of nvidia driver (for e.g. nvidia-driver-470) along with cuda toolkit (11.2 or 11.4) using instructions here and here. In the instructions, you can follow the commands for Ubuntu distro.
With my ASUS Zenbook Pro 15 UX550 with a GeForce GTX 1050 Mobile, in order to get it working again, I had to downgrade to the Nvidia driver nvidia-driver-470 (meta) package and follow the instructions in the setup script here.
Rishon_JR
  • 1,028
Piers
The same issue was with me. It seems my monitor is missing the proper information to wake up from the PC, so I tried to change my HDMI cable, and yes, it works. Before, I was using a cheap $1.7 HDMI cable.
although there was no problem with the VGA port or cable.
Martin
