I've installed ubuntu 16.04 LTS, removing windows 7, through bootable pen. Everything went well during installation. With ubuntu already running, after doing all the updates, most of the times, after a while my touchpad and keyboard freezes. First, I'm unable to click anywhere but can move mouse, no keyboard working. Then, mouse freezes completlty.
Tried the solution displayed at: Touchpad stops working after a while, Ubuntu 14.10, Dell Latitude E7440
rm -rf /etc/modprobe.d/blacklist_i2c_hid.conf
And at: Proper touchpad thumb & palm detection with libinput
sudo apt-get install xserver-xorg-input-libinput
sudo apt-remove xserver-xorg-input-synaptics
Then added some configurations
sudo vi /usr/share/X11/xorg.conf.d/90-libinput.conf
Section "InputClass"
    Identifier "libinput touchpad catchall"
    MatchIsTouchpad "on"
    MatchDevicePath "/dev/input/event*"
    Driver "libinput"
    Option "Tapping" "True"
    Option "DisableWhileTyping" "True"
EndSection
Still, after this, it froze again. All I can do is force shutdown.
Anything else I can or should do?
Just want to thank and confirm this has helped me.
TLDR: I use Dell Latitude E6420 with Ubuntu 21.10, the package name used is nvidia-driver-390.
sudo apt install nvidia-driver-390
First I tried driver version 495 (package name: nvidia-driver-495), it rebooted and go to to safe graphics - 640x480 resolution. Then did "grep -i nvidia /var/log/dmesg", it stated that Nvidia NVS 4200 is detected but support has been dropped on this version, the latest version supporting NVS 4200 is 390, pointing to https://www.nvidia.com/en-gb/drivers/unix/.
Hope this helps anyone else if the package version changes. It's been stable after installing this package, previously it locked up about 1 min after booting onto the graphical logon screen.
bluecaf
It was the graphics driver - i installed nvidia and works like a champ now (same issue, same pc)
Graphics issues after/while installing Ubuntu 16.04/16.10 with NVIDIA graphics
basically -
Ctrl+Alt+F1
to get into shell that won't get hosed when things freeze up
then:
sudo apt-get install nvidia-375
chris
  1. sudo gedit /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1 acpi_enforce_resources=lax"
  1. sudo bash -c 'echo -1 > /sys/module/usbcore/parameters/autosuspend'
  2. sudo nano /lib/udev/rules.d/60-persistent-v4l.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="04f2", ATTRS{idProduct}=="b36e" RUN+="/bin/sh -c 'echo enabled > /sys$env{DEVPATH}/../power/wakeup'"
4.cp /lib/udev/rules.d/60-persistent-v4l.rules /etc/udev/rules.d/
5.sudo nano /etc/rc.local
sudo sh -c "echo USB0 > /proc/acpi/wakeup" sudo sh -c "echo USB1 > /proc/acpi/wakeup" sudo sh -c "echo USB2 > /proc/acpi/wakeup" sudo sh -c "echo USB3 > /proc/acpi/wakeup" sudo sh -c "echo enabled > /sys/bus/usb/devices/3-1/power/wakeup"
=============also, get a usb powered hub, put the mouse on that.
mindtab
  • 56
