25
So libinput its nearing its first stable release with a release candidate
Which adds proper support for thumb / palm detection on touch pads along with swipe & pinch gesture support something dearly missed in Linux for multi touch capable laptops.
Can anyone provide a good instruction on how to install it on Ubuntu 15.04
As I believe we wont be seeing it as default in a Ubuntu installation for a while.
tomodachi
  • 15,370
For Ubuntu 15.10+ you can install libinput (wily, xenial, yakkety) through apt:
sudo apt install xserver-xorg-input-libinput
I did still have to edit the config file to enable tapping, I assume as Unity absorbs libinput it'll expose this via control panel settings (I used vi here, you can use gedit or whatever you like):
Edit the following file (tested on 16.04 2016-4-14 and 16.10 2016-10-14):
sudo vi /usr/share/X11/xorg.conf.d/90-libinput.conf
Adjust the 'touchpad' section to add Option "tapping" "True" and Option "DisableWhileTyping" "True" if you prefer this behavior:
Section "InputClass"
    Identifier "libinput touchpad catchall"
    MatchIsTouchpad "on"
    MatchDevicePath "/dev/input/event*"
    Driver "libinput"
    Option "Tapping" "True"
EndSection
Log out, log in .. enjoy! :)
Pablo Bianchi
  • 17,371
JimB
  • 586
16
This is how to install libinput to Ubuntu.
  1. Install some needed packages
    sudo apt-get install git build-essential autoconf automake pkg-config libtool
    sudo apt-get install libmtdev1 libmtdev-dev libudev-dev libevdev-dev xutils-dev libwacom-dev
  2. Install xserver-xorg-dev. For 14.04.3 it may be xserver-xorg-dev-lts-vivid. Be careful. You need to check what xserver-xorg package is installed.
    sudo apt-get install xserver-xorg-dev
  3. Clone libinput and xf86-input-libinput.
    git clone git://anongit.freedesktop.org/git/wayland/libinput
    git clone git://anongit.freedesktop.org/xorg/driver/xf86-input-libinput
  4. Build and install.
    cd libinput
    ./autogen.sh --prefix=/usr
    make && sudo make install
    cd ../xf86-input-libinput
  5. Add to file conf/90-libinput.conf string Option "Tapping" "True" before EndSection to the touchpad section.
  6. Copy config file to enable libinput.
    sudo cp conf/90-libinput.conf /usr/share/X11/xorg.conf.d/
Log off and log on.
You will see that libinput is used by running xinput list-props <your_touchpad_id>.
If you do not like using libinput, you can always disable it by
sudo rm /usr/share/X11/xorg.conf.d/90-libinput.conf
I just installed it, now I am figuring out how to setup palm detection. It looks like it is enabled by default, but I do not quite understand yet how does it use kernel reported width and pressure.
It looks like currently there are no major advantages of using libinput in Ubuntu.
xf86-input-libinput just wraps it to Xorg and nothing else. So extra gestures are not supported. At least I do not know if they do. Wayland or Mir will be more capable, I guess.
After some testing I found an advantage. There is an issue with xorg-synaptics that when you put a finger on button area, you can't use another finger to move cursor. That is inconvenient for people who like to use hardware buttons for clicking. That problem has been reported many times as a bug.
In libinput there is no this issue at all.
That was a fun to test. Thanks for the question.
Pilot6
  • 92,041
On 16.04 you have to install xserver-xorg-input-libinput-hwe-16.04 instead
Problem installing libinput on 16.04.2
I had a similar problem on Lubuntu 17. I tried installing libinput and editing the .conf file to no avail.
But then I saw @Pilot6 post above about using xinput to verify that libinput is active (would also be nice to know what's the criterion to verify for, but I digress).
I checked my xinput with xinput list-props 14 (could be a different number in your case).
which gave me a synaptics touchpad.
In the list there was an option for palm detection with a number associated to it (316).
So I used xinput set-prop 14 316 1 to activate palm detection. And it finally works.
