Xubuntu 16.04
$ uname -a
Linux private-client 4.4.0-57-generic #78-Ubuntu SMP Fri Dec 9 23:50:32 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
When connecting my new August EP650 bluetooth-headset, it pairs but I don't hear anything
With Pulse-Audio's configurations open you can watch a new item showing up immediately after pairing. On the left it is labelled "EP650" and there is a drop-down box named "HiFi-Stereo-A2DP-snk-profile" (I translated it from German)
but
$ sdptool search --bdaddr local a2snk
Failed to connect to SDP server on FF:FF:FF:00:00:00: No such file or directory
and
$ sdptool search --bdaddr local a2src
After reading some threads, I realized, that there is no: /etc/bluetooth/audio.conf
I am able to do some Linux-stuff you tell me, but I do not know what is wrong and do not know, how to get that file?
Does it come with any application?
Thanks for any helpful advise.
Byte Commander
  • 110,243
longman
  • 71
The audio.conf file is not needed. There is a bug in either Bluez or Pulseaudio causing issues if you want to use A2DP
A current work around is to
wget https://gist.github.com/pylover/d68be364adac5f946887b85e6ed6e7ae/archive/d698974910bbb7d016ec0ad08c1bf41b4b524364.zip
mv ~/d68be364adac5f946887b85e6ed6e7ae-d698974910bbb7d016ec0ad08c1bf41b4b524364/a2dp.py .a2dp.py
Then after connecting to the headset run ./a2dp.py in terminal and enter the number for your headset and let the python script do the rest
Jeremy31
  • 13,293
Get the index of your card:
pacmd list-cards
Set the cards profile to a2dp (example: index 2):
pacmd set-card-profile 2 a2dp_sink
Credit to develmusa of the ArchLinux forums: https://bbs.archlinux.org/viewtopic.php?pid=1720877#p1720877
Arthur
  • 231
Simply apply your required changes on /etc/bluetooth/main.conf instead of /etc/bluetooth/audio.conf as this file has been removed in new versions.
and for solve Failed to connect to SDP server on FF:FF:FF:00:00:00 see below link and make some changes on dbus-org.bluez.service to use features of blueZ-4 as sdptool in blueZ-5 not work properly.
https://raspberrypi.stackexchange.com/questions/41776/failed-to-connect-to-sdp-server-on-ffffff000000-no-such-file-or-directory
EsmaeelE
  • 425
  • 16
