If I want to make minor changes to the source code of a Debian package, how do I go about downloading, incrementing the package version, building the (modified) source, and installing it on my computer?
Asked
Active
Viewed 4.2k times
48
Here are two ways to do it. The first one is the classic form, you'll get the source with apt-get. The second is the new [ubuntu] way uses the bzr command.
Classic
$ apt-get source package
Then you'll be able to modify it:
$ cd package
$ vim some_file
Rebuild it:
$ sudo apt-get build-dep package
$ dch -i (which will open your editor to edit the changefile, here's where you can increment the package version)
$ debuild -us -uc -b
And install it:
$ sudo dpkg -i ../package.deb
New Ubuntu Approach
The new way (the Ubuntu way) is by using bzr branches, you'll get the code by using:
$ bzr branch lp:ubuntu/package #which will download the latest ubuntu package (the precise one)
$ bzr branch lp:ubuntu/oneiric/package #to get the package in oneiric
You can also get the code using:
$ pull-lp-source package #lp-source is part of the ubuntu-dev-tools pkg
pull-lp-source used to be called just lp-source in older versions.
Then you'll be able to edit it:
$ cd package
$ vim some_file
Rebuild it:
$ dch -i
$ debcommit
$ bzr bd -- -b -us -uc
And install it:
I recommend that you check the Ubuntu packaging guide out to know the details.
Also you might encounter problems if the package depends of others.
Alexis Wilke
- 2,787
Javier López
- 1,476
