I apologize in advance if this is covered in a previous post. However, I've searched and searched and have only found solutions for people with access to an ethernet connection. I am currently running windows 8.1 using my netgear A6100 wireless USB adapter, and unfortunately it is the only access I have to the internet. According to previous posts i've found, such as
and
I need the 8812au driver in order to get wireless access from my netgear A6100.
this would be great
sudo apt-get update
sudo apt-get install linux-headers-generic build-essential git
git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux.git
cd ~/rtl8812AU_8821AU_linux
make
sudo make install
sudo modprobe 8812au
except I can't install anything via this route because I do not have a temporary ethernet connection.
My question is, is there any way I can download this driver in windows, save it to a storage device, and open it in ubuntu and compile it offline?
Many thanks!
zak
  • 13
You can do the following:
  1. On another computer go to that github site: https://github.com/abperiasamy/rtl8812AU_8821AU_linux and download the zip (bottom right)
  2. Put that zip on a flash drive
  3. Boot into ubuntu
  4. Unzip the zip with unzip [file name] or do it by right clicking in your file manager
  5. cd to that folder (step 4 in your steps) and follow your steps from there.
EDIT: You'll probably need build-essential if it's not already installed:
http://packages.ubuntu.com/precise/build-essential
Linux headers generic here: http://packages.ubuntu.com/trusty/linux-headers-generic
Mitch
  • 4,807
I wana share this and give some credit for him! working great with Ubuntu 17.10. I think it will work debian, mint also. Original link https://github.com/zebulon2/rtl8812au-driver-5.2.9
My guide for you
download: https://github.com/zebulon2/rtl8812au-driver-5.2.9/archive/master.zip
Unzip it!
Open terminal in that folder (right click open terminal) then:
sudo dpkg -i gord-rtl8812au-dkms_1.0-13_amd64.deb
unplug/plug it in and wola! Why it has to be so hard all the time? ;)
If you want to remove it:
sudo dpkg -P gord-rtl8812au-dkms
