I need to mute/unmute from the command line. I found out that I can do it with:
amixer sset Master mute
amixer sset Master unmute
the problem is that the command for unmute is not working (as described also in this bug report: https://bugs.launchpad.net/ubuntu/+source/alsa-utils/+bug/878986)
My question is: is there another way to obtain the same result, taken that amixer is not working?
Furthermore, if I set manually the volume to minimum and then call
amixer sset Master 100%
the volume increases but doesn't switch to maximum, even if the stdout tells:
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 31
Mono:
Front Left: Playback 31 [100%] [0.00dB] [on]
Front Right: Playback 31 [100%] [0.00dB] [on]
Can anybody help me with this?
earthmeLon
  • 11,658
giuspen
  • 383
7 Answers7
16
Even better is this one, unmute all audio devices. and set volume to 70%
for x in `amixer controls  | grep layback` ; do amixer cset "${x}" on ; done
for x in `amixer controls  | grep layback` ; do amixer cset "${x}" 70% ; done
in the example above the HDMI and optical isn't unmutted..
psukys
  • 3,670
ThcTLo
  • 161
Try the following commands in a terminal
amixer -c 0 set Master playback 0% mute
amixer -c 0 set Master playback 100% unmute
This should ensure all outputs are controlled. It's likely with your posted commands the reason the volume is not 100% is that the amixer does not release all outputs eg headphones or any other sound outputs at the same time.
Mark Rooney
  • 6,329
Get all sounds sources, get their names, form a command line with amixer and execute it
amixer scontrols | grep -oE "'.*'" | awk -F\' \
 '{print "amixer -c 0 set \""$2"\" unmute 100"}' | sh
Unmutes all audio devices and sets their volume to max.
Have a great one, Mike
muru
  • 207,228
Mike
  • 51
Mark Rooney's solution did not work for me, but I was able to work around this by explicitly unmuting all of the channels.
#!/bin/bash
for i in Master Headphone PCM Front Surround Center LFE Side; do
    amixer -c 0 set "$i" playback unmute
done &>/dev/null
I got the channel names but running alsamixer.
kos
  • 41,268
Ok, first you need to know your different card numbers from
alsamixer
select cards from F6 and note the card number that has Master option
If you use headphones, then we change both Master and Headphone
amixer -c 1 set Master toggle && amixer -c 1 set Headphone toggle
where -c specifies the card number, 1 in this command.
The commands you are using doesn't work for me either, but try these. They work for me.
amixer set Master 0
amixer set Master 100
per
The accepted answer from Mark Rooney didn't help me because that command gave me an error (my sound card has number 1):
amixer: Mixer attach hw:1 error: Invalid argument
So I tried
amixer set Master 100 unmute
and it worked perfectly for currently selected sound card. You can also mute it using
amixer set Master 0 mute
