119
How do you mute the sound system from the command line?
Braiam
  • 69,112
myusuf3
  • 35,659
7 Answers7
94
Assuming you're using ALSA driver, run:
amixer set Master mute
amixer set Master unmute
Or, you can just use:
amixer set Master toggle
to toggle mute on and off.
Eric Carvalho
  • 55,453
goric
  • 3,916
64
This worked for me when others didn't:
amixer -q -D pulse sset Master toggle
This is from the link in nutty about natty's comment to the first answer:
Pablo Bianchi
  • 17,371
Tim
  • 33,500
56
I'm using pactl in my scripts. From man page:
set-sink-mute SINK 1|0|toggle: Set the mute status of the specified sink (identified by its symbolic name or numerical index)
To mute:
pactl set-sink-mute @DEFAULT_SINK@ true
To unmute:
pactl set-sink-mute @DEFAULT_SINK@ false
To toggle:
pactl set-sink-mute @DEFAULT_SINK@ toggle
Use 0 instead of @DEFAULT_SINK@ to set the sink with numerical index 0. true=="1", false=="0".
Tested on Ubuntu 12.10.
In my setup sometimes amixer unmute fails for some reason.
Pablo Bianchi
  • 17,371
17
On the terminal type this to mute
type
Tested on my Ubuntu 10.10.
Pablo Bianchi
  • 17,371
theTuxRacer
  • 16,533
10
If you are using alsa follow goric answer.
PulseAudio is better, but not so simple: pactl set-sink-mute 0 1 Do the work for the first device, but not if you are using headphones of another sink output.
The better way is to check with pactl info and get the Default Sink to use.
DEFAULT_SINK=$(pactl info | grep "Default Sink" | cut -d " " -f3)
Then to mute:
pactl set-sink-mute "$DEFAULT_SINK" "1"
Or unmute:
pactl set-sink-mute "$DEFAULT_SINK" "0"
I wrote a script to manage pulseaudio in my note. If you want to use, save it as volume, provide execute permissions chmod +x volume and add it to your path ln -sv $PWD/volume /usr/local/bin/. Here my script:
#!/bin/bash
# script name: volume
# Author: glaudistong at gmail.com
# depends on: yad, coreutils, pulseaudio
ps -ef | grep "yad" | grep -E "Volume [^+\-]" | tr -s " " | cut -d " " -f2 | xargs -i kill "{}" 2>/dev/null
DEFAULT_SOURCE=$(pactl info | grep "Default Source" | cut -d " " -f3)
case "$1" in
    init)
        ps -fe | grep yad | grep -q volume ||
         yad --notification --command "volume up" --text "+ Volume +" --image ~/Pictures/volume-up-dark.png &
         yad --notification --command "volume down" --text "- Volume -" --image ~/Pictures/volume-down-dark.png &
    up)
        pactl set-sink-volume "$DEFAULT_SINK" +5%
        P=$(pactl list | grep -E "Name: $DEFAULT_SINK$|Volume" | grep "Name:" -A1 | tail -1 | cut -d% -f1 | cut -d/ -f2 | tr -d " ")
        iconl="$(echo -ne "\U1F50A")"
        iconr="$(echo -ne "\U1F56A")"
        timeout .6 yad --progress --percentage "$P" --timeout 1 --no-buttons --undecorated --text="$iconl Volume $P% $iconr" --no-focus --center --skip-taskbar --on-top &
    down)
        pactl set-sink-volume "$DEFAULT_SINK" -5%
        iconl="$(echo -ne "\U1F509")"
        iconr="$(echo -ne "\U1F569")"
    mute)
        ismute=$(pactl list | grep -E "Name: $DEFAULT_SINK$|Mute" | grep "Name:" -A1 | tail -1 |cut -d: -f2| tr -d " ")
        if [ "$ismute" == no ]; then
            s=1
            P=0
            icon="$(echo -ne "\U1F507")"
        else
            icon=""
            s=0
        fi
        pactl set-sink-mute "$DEFAULT_SINK" "$s"
        echo $s > /sys/devices/platform/thinkpad_acpi/leds/platform::mute/brightness
        timeout .6 yad --progress --percentage "$P" --timeout 1 --no-buttons --undecorated --text="$icon Volume $P%" --no-focus --center --skip-taskbar --on-top &
    mic-up)
        pactl set-source-volume "$DEFAULT_SOURCE" +5%
        P=$(pactl list | grep -E "Name: $DEFAULT_SOURCE$|Volume" | grep "Name:" -A1 | tail -1 | cut -d% -f1 | cut -d/ -f2 | tr -d " ")
        icon="$(echo -en "\U1F3A4")"
        timeout .6 yad --progress --percentage "$P" --timeout 1 --no-buttons --undecorated --text="$icon Volume Mic $P%" --no-focus --center --skip-taskbar --on-top &
    mic-down)
        pactl set-source-volume "$DEFAULT_SOURCE" -5%
    mic-mute)
        ismute=$(pactl list | grep -E "Name: $DEFAULT_SOURCE$|Mute" | grep "Name:" -A1 | tail -1 |cut -d: -f2| tr -d " ")
            s=1
            P=0
            icon="$(echo -en "\U1F507\U1F3A4")"
        else
            s=0
        fi
        pactl set-source-mute "$DEFAULT_SOURCE" "$s"
        echo $s > /sys/devices/platform/thinkpad_acpi/leds/platform::micmute/brightness
        echo invalid option;;
esac;
Kulfy
  • 18,154
ton
  • 221
if your are using pulseaudio as the sound server then do this
pactl -- set-sink-mute @DEFAULT_SINK@ toggle # Also true/false to mute/unmute
to mute and unmute
if using alsa then use this
amixer sset 'Master' toggle
to mute and unmute
Pablo Bianchi
  • 17,371
xset b off
just worked like a charm for me.
The command xset b off is used to disable the audible "beep" sound when running an X Window System (like GNOME, KDE).
Here's a breakdown:
  • xset is a utility for setting various user preferences.
  • b stands for "bell," which controls the system bell sound.
  • off tells xset to turn the bell sound off.
When you run xset b off, the system bell will no longer beep in response to certain actions (like pressing backspace in an empty text field).
Pierre
  • 101
