I have Kubuntu 16.04 64-bit installed on my HP Pavilion 17-f000 Notebook. I've tried the steps from the ubuntu 16.04 wiki, but the sudo pm-hibernate terminal command did nothing and creating the /etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla file with these contents also had had no effect:
[Re-enable hibernate by default in upower] Identity=unix-user:* Action=org.freedesktop.upower.hibernate ResultActive=yes
[Re-enable hibernate by default in logind] Identity=unix-user:* Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.hibernate-multiple-sessions ResultActive=yes
I have 5.8GiB ram, 7.5GiB swap partition, and suspending to ram works fine.
This is probably due to changes & regressions introduced in the 4.4.0 kernel such as this with Ubuntu 16.04, but I do have a workaround for 4.4.0:
I first added my swap partition to grub, rebooted, and there was no change. Next I installed the Ubuntu kernel packages with TuxOnIce stable and the option to hibernate appeared, but that failed. I later I installed the package hibernate which uses uswsusp for suspending to disk & ram and that worked. Below are the exact steps to achieve this:
  1. Double check if your swap partition/file(s) are setup correctly in /etc/default/grub; you can do so by checking the location with either cat /proc/swaps or swapon -s.
    Better yet, find out the UUID or label of the swap partition/files(s) and use that:
    tail -n -9 /proc/swaps | cut -d ' ' -f 1 | xargs sudo blkid
  2. Edit /etc/default/grub by finding the line with GRUB_CMDLINE_LINUX_DEFAULT=, add your swap device(s), and save. To enter the UUID, prefix it with UUID= or /dev/by-uuid/.
  3. Save changes to GRUB:
    sudo update-grub
  4. Add the TuxOnIce stable repository:
    sudo add-apt-repository ppa:tuxonice/ppa
  5. Install TuxOnIce kernel & uswsup:
    sudo apt update
    sudo apt install uswsusp linux-generic-tuxonice tuxonice-userui
  6. Restart your computer (sudo reboot;)
vaselo
I had the exact same problem in Ubuntu 16.04, and nothing seemed to help.
I finally figured out that I just had to disable Secure Boot in the BIOS menu. I had already done the steps suggested in the accepted answer, so I can't say whether they were necessary in my case.
danmou
  • 201
