27
Following my previous experiences with setting up Cisco AnyConnect VPN connections on Ubuntu 14.04 I tried the same approach here by installing packages:
sudo apt-get install -y network-manager-openconnect-gnome network-manager-openconnect network-manager-vpnc network-manager-vpnc-gnome vpnc vpnc-scripts
Even after this an option to create Anyconnect compatible VPN connection does not appear.
Ubuntu 16.04 64bit, stock.
Randall
  • 356
6 Answers6
21
I am having the same problem on fresh install of Ubuntu 16.04. You can however connect via terminal :
sudo openconnect https://<remote.host.here>
after that you should be prompted for user name and password.
heemayl
  • 93,925
bart
  • 331
I had same problem. use package in this page (or build it if you don't trust) http://tomtomtom.org/networkmanager-openconnect/
It works for me
On Ubuntu 16.04 the network-manager-openconnect and network-manager-openconnect-gnome plugins are not usable because they are to old to use with the current version of network-manager.
This is the english version of this guide from a german ubuntu support forum.
Unofficial built packages are available here:
http://tomtomtom.org/networkmanager-openconnect_1.1.93-1_i386.deb
http://tomtomtom.org/networkmanager-openconnect_1.1.93-1_amd64.deb
NOTE: You won´t get any security updates for this! It is just a workaround until the packages will have been fixed in the official repository!
Using VPN is a security feature - so it is better to build the package manually from source because you don´t know what I put into the packages. :-P
At first remove the unusable packages
sudo apt-get purge network-manager-openconnect network-manager-openconnect-gnome
You will need the build-dependencies.
sudo apt-get build-dep network-manager-openconnect
(NOTE: For this the 'deb-src'-Sources in /etc/apt/sources.list must be active.)
You can do this with sed e.g.
sudo sed -i s/#deb-src/deb-src/g /etc/apt/sources.list
the new dependency for the new version.
sudo apt-get install libnm-dev
and the sourcecode from GNOME project.
wget http://ftp.gnome.org/pub/GNOME/sources/NetworkManager-openconnect/1.1/NetworkManager-openconnect-1.1.93.tar.xz
Unpack the tarball
tar -xf NetworkManager-openconnect-1.1.93.tar.xz
change to the unpacked directory
cd NetworkManager-openconnect-1.1.93
and run the configure script.
./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var
            --libexecdir=/usr/lib/NetworkManager/
            --enable-more-warnings=yes --disable-static
start compiling .
make
and install manually
sudo make install
install the dependency for use the software
sudo apt-get install openconnect
or build a package with checkinstall
sudo checkinstall
If you do so enter this:
networkmanager-openconnect as package name
adduser, libc6, libdbus-glib-1-2, libglib2.0-0, libnm-glib-vpn1, libnm-util2, network-manager, openconnect as requirements
and
network-manager-openconnect, network-manager-openconnect-gnome
as conflicts.
If you get errormessages by installing the package try
sudo apt-get -f install
to resolve unmet dependencies.
To use the software it is necessary to add a systemuser for this
sudo adduser --system --quiet --home /var/lib/NetworkManager
             --no-create-home
             --gecos "NetworkManager OpenConnect plugin"
             --group nm-openconnect}
At last restart the system.
Randall
  • 356
There seems to be an official fix in xenial-proposed. If you enable pre-release updates and then do:
sudo apt install network-manager-openconnect network-manager-openconnect-gnome
it will start working. Well, it worked for me at least :)
Jeremy
  • 533
To supplement Morteza Pourkazemi's answer, the answer works for me, but I need to install the following packages which are required by the configure command.
sudo apt-get install intltool libxml2-dev libgtk-3-dev libsecret-1-dev libopenconnect-dev network-manager-dev libnm-util-dev libnm-glib-dev libnm-glib-vpn-dev
heemayl
  • 93,925
HD189733b
  • 513
I think the issue appears to be that the openconnect plugin is missing a library that network manager now requires.
If I examine the files in /etc/NetworkManager/VPN I see that all of the plugins except openconnect have a section that looks like the following:
[libnm]
plugin=/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-vpn-plugin-vpnc.so
network-manager-openconnect-gnome does not appear to provide a similar library and nor does any package in the ubuntu repository. I think this libnm library is some new requirement of NetworkManager and the version of openconnect in ubuntu doesn't support it yet.
Since I upgraded to 16.04 from 15.10 I still have my VPN connection defined. I can select and login from the NM GUI. However I cannot edit the connection via the GUI nor can I add a new VPN connection using openconnect.
Ethan
It is not at all difficult to do this with a CLI instead of a GUI:
openconnect -c ~/path/to/your/client_cert.pem  \
            -k ~/path/to/your/private_key.pem  \
            -b #for background
            $VPN_Address
There are also options for giving it your username / password - so throw those in and add the script to startup, and you'll never even have to think about it.
rm-vanda
  • 3,202
