Is it possible to install and run Pulse Secure on wine? I have setup the environment variable WINEARCH=win32 as well as selected Windows 7 under winecfg.
When I run wine start JunosPulse.x86.msi the installer "fails prematurely" with the following output to terminal:
fixme:exec:SHELL_execute flags ignored: 0x00000100
> fixme:storage:create_storagefile Storage share mode not implemented.
err:rpc:I_RpcGetBuffer no binding
fixme:msi:AutomationObject_GetIDsOfNames Unknown member L"CreateObject", clsid {000c109e-0000-0000-c000-000000000046}
fixme:shell:ShellDispatch_QueryInterface not implemented for {fc4801a3-2ba9-11cf-a229-00aa003d7352} (unknown)
fixme:shell:ShellDispatch_QueryInterface not implemented for {a6ef9860-c720-11d0-9337-00a0c90dcaa9} (unknown)
fixme:vbscript:do_mcall NULL obj
err:msi:ITERATE_Actions Execution halted, action L"writeTncConfigFile.D7CCF602_E814_4416_8EC5_24D6FEA3289C" returned 1603
err:msi:ITERATE_Actions Execution halted, action L"ExecuteAction" returned 1603
fixme:msvcrt:__clean_type_info_names_internal (0x65b260) stub
The backstory is I have tried both: using openconnect as well as tethering to my Pulse Secure authenticated Android device with no success. I have also tried using the Pulse Secure Debian command-line tool, but it seems that SAML authentication is not supported at this time.
jerome
  • 837
err:msi:ITERATE_Actions Execution halted, action L"writeTncConfigFile...." returned 1603
Try to re-/install or upgrade your .NET framework (4.5.3+) as per this thread.
You can also try to run MSI installer by:
wine msiexec /i filename.msi
kenorb
  • 10,944
You can't install a VPN client in Wine, generally speaking.
VPN software relies on some network adapter in the kernel to pass traffic to and from the network stack. On Linux this is commonly a TUN/TAP device, which passes traffic to a user space program. Windows has a defined interface for network adapters - which is not equal to Linux interface.
So a driver made for Windows will not work in wine. You can not install your Windows VPN client in wine and make it work, no matter what you do. You need to make openconnect work, or run a windows virtual machine. It's possible you could make your Windows machine forward traffic to your Linux machine.
vidarlo
  • 23,497
