26
I have network-manager-openconnect-gnome installed, but there is no option for OpenConnect in Network Manager. If I run
sudo openconnect vpn.work.com
And enter my details, I can connect to my work VPN, so openconnect is installed and working, but it just isn't showing up in Network Manager.
6 Answers6
20
ubuntu man page
VPN support Network Manager VPN support is based on a plug-in system. If you need VPN support via network manager you have to install one of the following packages:
network-manager-openvpn network-manager-vpnc network-manager-openconnect
The network-manager-pptp plugin is installed by default.
On GNOME, you also need to install the -gnome packages for the VPN plugin you choose:
network-manager-openvpn-gnome network-manager-vpnc-gnome network-manager-openconnect-gnome
Mert
  • 211
This should generally be solved by restarting your machine, and if you don't want to do so try:
# reloads all new or changed systemctl units
sudo systemctl daemon-reload
and then
# restart the network daemon
sudo service network-manager restart
None of the answers here are correct based on the question. For completeness (since this seems to be the only question that comes up when googling the problem):
This will fix the issue on 16.04+
sudo apt install network-manager-openconnect network-manager-openconnect-gnome
sudo systemctl restart network-manager.service
The *-gnome package is needed for the GUI components. Note that a reboot or restart of the network-manager.service is required in order to see the change.
Update: Added restart of network-manager service instead of reboot as per @lane
here is what fixed the issue on my ubuntu 18.10 installation:
after installing the network-manager pluings using
I had to reboot my system. simply restarting network-manager did not help, so it must be something else like a gnome component or so, that needs to be restarted as well
I also have "grayed out VPN" in Network-Manager this is what I found (I'm Newbie)
On Ubuntu 16.04 the network-manager-openconnect and network-manager-openconnect-gnome plugins are not usable because they are to old to use with the current version of network-manager.
This is the english version of this guide from a german ubuntu support forum - Fixing unusable network-manager-openconnect-plugin on Xenial Xerus
Unofficial built packages are available here:
http://tomtomtom.org/networkmanager-openconnect_1.1.93-1_i386.deb
http://tomtomtom.org/networkmanager-openconnect_1.1.93-1_amd64.deb
NOTE: You won´t get any security updates for this! It is just a workaround until the packages will have been fixed in the official repository!
Randall
  • 356
The same problem. Couldn't start sudo apt-get network-manager-openconnect problem - have no candidate for 'openconnect'
Solution:
sudo add-apt-repository ppa:openconnect/daily
sudo apt-get update
Source - https://launchpad.net/~openconnect/+archive/ubuntu/daily and try to install.
Thomas
  • 6,433
