As usual, when I install a new version of Ubuntu I install pam_mount to automount my with LUKS encrypted partition on login. However, for Ubuntu 11.10, I followed the same procedure as usual, but I can't make it work.
The encrypted partition is
/dev/sda5
and I added the information
<volume user="user" fstype="crypt" path="/dev/sda5" mountpoint="/media/personal" options="fsck,relatime" />
to
/etc/security/pam_mount.conf.xml.
The partition does show up in Nautilus but is not mounted. Any idea?
Edit:
There are no error messages or other information in the terminal, pointing to a false password or configuration error.
n3rd
  • 480
Now it is working again. The reason it did not work is indeed because they changed the format of the config file
in Ubuntu 11.10. So, I backed up my old *pam_mount.conf.xml* and uninstalled the pam-mount module via
apt-get remove --purge libpam-mount
and reinstalled it using
apt-get install libpam-mount
Now I opened the new
and inserted this line,
from my old config file into the volume section of the new config file.
This is how it look now
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE pam_mount SYSTEM "pam_mount.conf.xml.dtd">
        See pam_mount.conf(5) for a description.
<pam_mount>
                <!-- debug should come before everything else,
                since this file is still processed in a single pass
                from top-to-bottom -->
<debug enable="0" />
                <!-- Volume definitions -->
<volume user="user" fstype="crypt" path="/dev/sda5" mountpoint="/media/personal" $
                <!-- pam_mount parameters: General tunables -->
<luserconf name=".pam_mount.conf.xml" />
<!-- Note that commenting out mntoptions will give you the defaults.
     You will need to explicitly initialize it with the empty string
     to reset the defaults to nothing. -->
<mntoptions allow="nosuid,nodev,loop,encryption,fsck,nonempty,allow_root,allow_ot$
<mntoptions deny="suid,dev" />
<mntoptions allow="*" />
<mntoptions deny="*" />
<mntoptions require="nosuid,nodev" />
<logout wait="0" hup="0" term="0" kill="0" />
                <!-- pam_mount parameters: Volume-related -->
<mkmountpoint enable="1" remove="true" />
</pam_mount>
n3rd
  • 480
I think here is good starting point to solve this issue is to temporary add "debug" option after pam_mount.so module (in /etc/pam.d/common.auth and common.session), set 'debug enable="1"' in /etc/security/pam_mount.conf.xml, login again and check /var/log/auth.log for additional info
domelaz
