My 10.04 machine uses three partitions: 5 GB for /boot, 25 GB for / and 120 GB for /home. / and /home are encrypted with LUKS passphrase.
I've downloaded the alternate installer in order to reinstall the machine. I want my / partition to be rewritten, but to keep my existing /home.
Any way to tell the installer my /home already exists in a separate LUKS partition?
Thanks in advance,
Adam
Adam Matan
  • 12,919
What I would do is to reinstall using /boot and / and leave the /home partition alone during the install. Once you have installed you can install cryptsetup, set up your partition in /etc/crypttab and /etc/fstab and you'll be away. I'll assume you have an encrypted swap For the details, once you have installed and rebooted, open a terminal and:
sudo apt-get install cryptsetup
cryptsetup luksOpen /dev/sda6 crypthome
cd /
mount -t ext4 /dev/mapper/crypthome /home
Edit the partition details and file system type as required. Now you can browse /home and ensure it is what you expect. Then you need to put the following in /etc/crypttab
crypthome /dev/sda6 none         luks
cryptswap /dev/sda7 /dev/urandom swap
And in /etc/fstab you need to add these lines to the end
/dev/mapper/crypthome  /home  ext4  defaults  0  2
/dev/mapper/cryptswap  none   swap  sw        0  0
Do a reboot to check it all works as expected and you're away :)
Hamish Downer
  • 19,506
