196
What I am looking for is to have system wide implementation of sound enhancements like bass boosts, echoes, Fidelity, Stereo enhancement and so on.
Audio Video players have their own equalizer but they enhance only the audio / video files they are playing.
So to enhance sounds playing such as: YouTube, Spotify, System Sound, etc. I need a enhancer software. Back in Windows, I used to use SRS HD audio lab to do the same.
P.S. I have a horrible Speaker set.
Braiam
  • 69,112
user15873
  • 2,063
9 Answers9
211
PulseAudio Equalizer is the way to go.
Here’s a blog post about it: http://www.webupd8.org/2013/10/system-wide-pulseaudio-equalizer.html
Since pulseaudio-equalizer is part of Ubuntu 17.04, you can simply enable the universe repository and then issue the installation command:
sudo apt-get install pulseaudio-equalizer
For older releases, add the PPA first:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
After PulseAudio Equalizer is installed, you can launch its GUI with the applications qpaeq or pulseaudio-equalizer-gtk.
PulseAudio Multiband EQ window
David Foerster
  • 36,890
  • 56
  • 97
  • 151
greg
  • 10,693
20
Psyke83's on the Ubuntu Forums wrote a 'script' to do this for PulseAudio.
Ubuntu 10.10:
Currently the easiest method is to install from a deb created by WebUp8.
Ubuntu 10.04 and below:
There is a PPA containing the equalizer:
sudo add-apt-repository ppa:psyke83/ppa
sudo apt-get update && sudo apt-get install pulseaudio-equalizer
alt text
8128
  • 28,868
dieki
  • 3,412
19
This list is roughly sorted from simple to professional and of course far from being complete.
Alsaequal
Alsaequal
Alsaequal is an equalizer plugin for the (usually preinstalled) command-line audio mixer alsamixer as well as amixer.
Installation
sudo apt install libasound2-plugin-equal
Start
alsamixer -D equal
amixer -D equal
To change to the equalizer in the running program, press F6, choose enter device name... and enter “equal”.
Configuration
You can find configuration tipps on wiki.archlinux.org, e. g. how to save and load custom presets.
Installation
Ubuntu 14.04 Trusty and 16.04 Xenial
Follow these instructions on webupd8.org.
Ubuntu 18.04 and later
sudo apt install pulseaudio-equalizer
Start
qpaeq
If you encounter an error and are told to make sure you have the pulseaudio dbus module loaded follow the instructions in this answer.
JackEQ
JackEQ
Installation
sudo apt install jackeq
Requirements
JackEQ needs a configured and running JACK Audio Connection Kit, a howto is provided by this article on libremusicproduction.com.
JAMin
JAMin
JAMin is the JACK Audio Connection Kit (JACK) Audio Mastering interface (…) designed to perform professional audio mastering of stereo input streams. source
Installation
sudo apt install jamin
Requirements
JAMin needs a configured and running JACK, a howto is provided by this article on libremusicproduction.com.
JACK Rack with LADSPA effects
JACK Rack
JACK Rack is a sound studio rack where you can store and combine LADSPA effect plugins. A collection of plugins is contained in the ubuntustudio-audio-plugins package. More on ladspa.org.
Installation
sudo apt install jack-rack
Requirements
JACK Rack needs a configured and running JACK, a howto is provided by this article on libremusicproduction.com.
Advanced audio software – normally using the JACK Audio Connection Kit – of course also comes with equalizing features. As I feel like this goes beyond the scope of this question, here's just a short list with links.
Further information about audio software can be found on the German Ubuntu wiki wiki.ubuntuusers.de.
dessert
  • 40,956
I was looking for a graphical eq package for Ubuntu 12.04 and found this post. Thanks a lot for this!
Unfortunately the link provided for WebUp8's deb is no longer valid, but there's this one that I found hosted on UbuntuUpdates.org and works perfectly.
I found that the easiest way of installing it is via the deb package. Installs right away w/o hassle. And this little thingy works, eh? Even stays permanently after a reboot! System-wide all the way**.
**Actually, I realized why: the eq application is just a frontend for adjusting the DSP's eq settings in PulseAudio; so mainly it's PulseAudio (ALSA?) retaining the settings - the eq interface is just there to allow accessibility to these settings. (I'm a total Ubuntu noob, hope this makes sense)
Too bad it's no longer supported, I wonder why not. But works on Precise alright.
WMoecke
  • 61
If you use Ubuntu >= 18.04 you can try Pulse Effects.
EasyEffects (formerly known as PulseEffects) if the future of equalisation in 2021.
From official documentation, install it with sudo apt install pulseeffects
Or, if you want the latest version install the community packages:
echo "deb http://ppa.launchpad.net/mikhailnov/pulseeffects/ubuntu bionic main" | sudo tee /etc/apt/sources.list.d/mikhailnov-ubuntu-pulseeffects-bionic.list
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys FE3AE55CF74041EAA3F0AD10D5B19A73A8ECB754
echo -e "Package: * \nPin: release o=LP-PPA-mikhailnov-pulseeffects \nPin-Priority: 1" | sudo tee /etc/apt/preferences.d/mikhailnov-ubuntu-pulseeffects-ppa
sudo apt update
  1. Open it, select the speaker Icon in the top-left.
  2. Click onto Applications, this is where you enable the PulseEffects modification for the sound made by specific applications. Flick the switch on the application you want to modify.
  3. On the left, are your options, for an equalizer Tick Equalizer and open its menu for the controls.
PulseEffects Equalizer image
There are many other options which may also be useful, as well as manipulation for input sound as well.
Pablo Bianchi
  • 17,371
Baa
  • 3,750
I've recently described it here: Global_equalizer_for_ALSA
You can install PulseAudio with system-wide equalizer support. This is basically an update to the old PulseAudio System-Wide Equalizer. There are more details in this blog post.
If you want to enhance the sound quality itself you can take a look at https://web.archive.org/web/20190208002329/https://r3dux.org/2013/12/how-to-enable-high-quality-audio-in-linux/.
For convenience I'll summarise it here.
Edit /etc/pulse/daemon.conf and look for the following three lines. They may not be in the same place and they may be commented out.
; resample-method = speex-float-1
; default-sample-format = s16le
; default-sample-rate = 44100
Uncomment and update them to the following
resample-method = src-sink-medium-quality
default-sample-format = s24le
default-sample-rate = 96000
Finally restart pulseaudio (and possibly your music player(s))
pulseaudio -k
pulseaudio --start
For the resample-method you can also try src-sink-best-quality but that uses around twice the CPU time on my machine, with little noticeable difference to the medium setting.
On my machine (Intel Core i5-3210M 2.5GHz 3MB cache) pulseaudio hits around 50% when using the src-sink-best-quality resampling method and around 20% on src-sink-medium-quality while playing FLAC audio.
peterh
  • 293
  • 17
chriscz
  • 71
