Minimum Info
You are going to ask a question then add the link generated by this command
sudo apt-get install pastebinit; sudo sh -c "lsb_release -sd; dmidecode -s system-product-name; echo ==; lshw -c display; echo ==; xrandr --verbose; echo ==; cat /etx/X11/xorg.conf" | tee ~/Desktop/ubuntu-graphic-info.txt | pastebinit
Without dumping to a file and uploading it, just print on screen:
Note
Users could make vast custom changes, that may affect display. It is hard to capture all of them as also raises concerns when blindly collecting files in folders. Best if the user declare by him/herself the changes from vanilla copy:
- Grub/Kernel boot options
- X11 settings
- Udev
- Manual driver install
- Kernel/RAMDisk builds
Troubleshooting
Little talk
Much complicated than I thought, as I tried playing with my Intel GPU for some time using xrandr. Sometimes, I get an unexpected errors. This is a summery for my experience.
Here is a simplified full stack list, as I understand it.
xrandr
└─ Xorg (w/ driver specific module)
└─ kernel
└─ driver
graphic card
└─ cables (kvm switch/connection adapter)
└─ monitor
It is really a large stack to troubleshoot, more difficult with old hardware
and the rolling proprietary drivers updates, even a bad pin contact in DB-15
VGA cable (or cheap cable) can make a difference. Actually, majority of
issues I read here in Ask Ubuntu are about simply missing/wrong EDID data from the monitor, blaming: cables (kvm switch/connection adapter). You can notice that quickly from xrandr --verbose output.
Many cases also are drivers restrict some modes because of incomplete/partially wrong EDID data from the Monitor (Manufacturer mistake), User overcome this by writing custom xorg.conf to override: Mode, HSync & VSync, EDID, DPI ... depending on driver (nvidia for example can IgnoreEDID from monitor)
I recommend this to read for Advanced users or the ones providing help here:
Notice
Be careful while reading old documentations and posts providing solutions. Better, to look for documentation for that specific drive in use.
- Verify post date, last edit date or software version.
KMS, DRI or fb(framebuffer) driver type. (just be aware, I'm not an expert).
- Xorg have made a lot toward auto configure so
xorg.conf is not created by
default. Even if user have make one, he/she shouldn't create all sections but only overrides what's needed. It is kind of configuration on the fly.
My dummy understanding of those xrandr/X errors
The xrandr seems not aware of what driver is able or agree to provide (all driver capabilities), while Xorg is an interface between them. So any of following scenario may happen:
- high ratio: XRandR → (:) accept) Xorg → (:) accept) Driver , every one is happy!
- low ratio: XRandR → (:| accept) Xorg → (XD reject) Driver , life is hard sometimes!
- rare case: XRandR → (X/ reject) Xorg -x- (:| neutral) Driver , time for plan B!
So we get those error when Xorg or Driver are unable to process or refuse xrandr request due:
- Current Xorg settings
- Driver capabilities
- Graphics adapter capabilities
- Monitor capabilities got from EDID
- A bug in one of them including
xrandr
Collecting debug info for generic graphics!
Why? I looked at many questions here related to xrandr & resolution, they
are missing much info about the full stack setup. Considered set mentioned only the last failed command. Even, I would suggest putting the full outputs in the question so we can search for similarities and link the related issues.
If no EDID data found, start with:
- How are the monitor physically connected, ie is a KVM used? Any connection adapter ex. HDMI to VGA?
- Have you tried another cable?
- What is the monitor Brand/Model?
Here a list of some helpful commands
Background info
sudo dmidecode -s system-product-name
lsb_release -sd
Xorg -version
xrandr -v
sudo lshw -c display
Base info
xrandr --verbose
more /var/log/Xorg.0.log
Debug commands & options
sudo apt-get install edid-read
ls /sys/class/drm/*/edid | xargs -i{} sh -c "echo {}; parse-edid < {}"
xrandr --verbose ...
xtrace xrandr --verbose ...
#no need, only to compare between releases for changes, the default driver parameters
sudo sh -c "ls /sys/module/<driver-module-from-lshw>/parameters/ | xargs -L1 -i{} sh -c 'echo -n {} " " ; cat /sys/module/<driver-module-from-lshw>/parameters/{}'"
additional desktop environment setting, for general cases, gnome/unity
cat ~/.config/monitors.xml
cat /etc/gnome-settings-daemon/xrandr/monitors.xml
gsettings list-recursively org.gnome.settings-daemon.plugins.xrandr
Advanced debug options
Add Option "ModeDebug" "true" to Section "Device" to xorg.conf, see nvidia debug below for details.
Additional debug info for nvidia graphics!
cat /proc/driver/nvidia/version for precise version
Activating nvidia debug info to /var/log/Xorg.0.log
gksu nvidia-settings
# go to X configuration then export, copy only device section
sudo mkdir /etc/X11/xorg.conf.d/
sudo vim /etc/X11/xorg.conf.d/90_my_nvidia_hacks.conf
# paste the device section
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVS 3100M"
EndSection
add to it this line Option "ModeDebug" "true"
Full documentation at file:///usr/share/doc/nvidia-*/html/, look for same running version, there are many changes in available options and default settings.
A debugging test case with Intel driver: BadMatch (invalid parameter attributes)
Here is a case that I can reproduce it and it seems like bug in xrandr. It is clear from xtrace & Xorg.0.log, that the frame-buffer is not resized in 1st combination.
It seems a bug in xrandr. It raises an Xorg error when changing to bigger resolution without changing a previously defined scale.
system info
$ xrandr --version
xrandr program version 1.4.3
Server reports RandR version 1.4
$ sudo sh -c "lsb_release -dc;echo; uname -a; Xorg -version;echo; lshw -C display"
Description: Ubuntu 15.10
Codename: wily
Linux BlueSkies 4.2.0-25-generic #30-Ubuntu SMP Mon Jan 18 12:31:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
X.Org X Server 1.17.2
Release Date: 2015-06-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.13.0-68-generic x86_64 Ubuntu
Current Operating System: Linux BlueSkies 4.2.0-25-generic #30-Ubuntu SMP Mon Jan 18 12:31:50 UTC 2016 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.2.0-25-generic root=UUID=9f0530d5-e0eb-43fa-b99b-000fa742cf10 ro persistent quiet splash vt.handoff=7
Build Date: 12 November 2015 05:33:29PM
xorg-server 2:1.17.2-1ubuntu9.1 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.32.6
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
*-display
description: VGA compatible controller
product: 3rd Gen Core processor Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:26 memory:f6400000-f67fffff memory:e0000000-efffffff ioport:f000(size=64)
$ sudo sh -c "ls /sys/module/i915/parameters/ | xargs -L1 -i{} sh -c 'echo -n {} \" \" ; cat /sys/module/i915/parameters/{}'"
disable_display N
disable_power_well 1
disable_vtd_wa N
edp_vswing 0
enable_cmd_parser 1
enable_execlists 0
enable_fbc -1
enable_hangcheck Y
enable_ips 1
enable_ppgtt 1
enable_psr 0
enable_rc6 3
fastboot N
invert_brightness 0
load_detect_test N
lvds_channel_mode 0
lvds_downclock 0
lvds_use_ssc -1
mmio_debug 0
modeset -1
nuclear_pageflip N
panel_ignore_lid 1
prefault_disable N
preliminary_hw_support 0
reset Y
semaphores -1
use_mmio_flip 0
vbt_sdvo_panel_type -1
verbose_state_checks Y
$ modinfo i915
filename: /lib/modules/4.2.0-25-generic/kernel/drivers/gpu/drm/i915/i915.ko
license: GPL and additional rights
description: Intel Graphics
author: Intel Corporation
author: Tungsten Graphics, Inc.
firmware: i915/skl_dmc_ver1.bin
srcversion: BB05D6968744E69AEA30DC2
depends: drm_kms_helper,drm,video,i2c-algo-bit
intree: Y
vermagic: 4.2.0-25-generic SMP mod_unload modversions
$ xrandr
Screen 0: minimum 8 x 8, current 1726 x 768, maximum 32767 x 32767
LVDS1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1366x768 60.07*+ 40.02
1360x768 59.80 59.96
1280x720 60.00
1024x768 60.00
1024x576 60.00
960x540 60.00
800x600 60.32 56.25
864x486 60.00
640x480 59.94
720x405 60.00
680x384 60.00
640x360 60.00
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
DP3 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
HDMI3 disconnected (normal left inverted right x axis y axis)
VGA1 connected 360x200+1366+0 (normal left inverted right x axis y axis) 410mm x 230mm
1366x768 59.79 +
1280x1024 60.02
1280x720 60.00
1024x768 60.00
800x600 60.32
640x480 60.00
720x400 70.08*
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Other info not collected
$ grep intel /var/log/Xorg.0.log
case reproducing & debug
1st combination different mode & same scale
$ xrandr --output VGA1 --mode 720x400 --right-of LVDS1 --scale 0.5x0.5
$ xtrace xrandr --verbose --output VGA1 --mode 1366x768 --right-of LVDS1 --scale 0.5x0.5
000:<:0030: 28: RANDR-Request(140,21): SetCrtcConfig crtc=0x00000040 timestamp=0x00000000 config timestamp=0x00010a4d x=0 y=0 mode=0x00000000 rr=Rotate_0 outputs=;
000:>:0030:32: Reply to SetCrtcConfig: status=Success(0x00)
screen 0: 1726x768 453x202 mm 96.57dpi
crtc 1: 720x400 70.08 +1366+0 "VGA1"
000:<:0031: 20: RANDR-Request(140,7): SetScreenSize window=0x000000d9 width=1726 height=768 width[mm]=453 height[mm]=202
000:<:0032: 32: RANDR-Request(140,21): SetCrtcConfig crtc=0x00000040 timestamp=0x00000000 config timestamp=0x00010a4d x=1366 y=0 mode=0x000000fc rr=Rotate_0 outputs=0x0000004a;
000:>:0032:32: Reply to SetCrtcConfig: status=Success(0x00)
screen 0: 2049x768 538x202 mm 96.57dpi
crtc 1: 1366x768 59.79 +1366+0 "VGA1"
000:<:002f: 4: Request(36): GrabServer
000:<:0030: 20: RANDR-Request(140,7): SetScreenSize window=0x000000d9 width=2049 height=768 width[mm]=538 height[mm]=202
000:<:0031: 32: RANDR-Request(140,21): SetCrtcConfig crtc=0x00000040 timestamp=0x00000000 config timestamp=0x00010a4d x=1366 y=0 mode=0x000000f8 rr=Rotate_0 outputs=0x0000004a;
000:>:0030:Error 8=Match: major=140, minor=7, bad=217
000:>:0031:32: Reply to SetCrtcConfig: status=Success(0x00)
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 7 (RRSetScreenSize)
Serial number of failed request: 48
Current serial number in output stream: 49
2nd combination same mode & different scale
$ xtrace xrandr --verbose --output VGA1 --mode 1366x768 --right-of LVDS1 --scale 1x1
screen 0: 2732x768 718x202 mm 96.57dpi
000:<:0030: 20: RANDR-Request(140,7): SetScreenSize window=0x000000d9 width=2732 height=768 width[mm]=718 height[mm]=202
000:<:0031: 56: RANDR-Request(140,26): SetCrtcTransform crtc=0x00000040 transform={matrix=1.000000,0.000000,0.000000,0.000000,1.000000,0.000000,0.000000,0.000000,1.000000;}; filter name='nearest' filter params=;
000:<:0032: 32: RANDR-Request(140,21): SetCrtcConfig crtc=0x00000040 timestamp=0x00000000 config timestamp=0x00010a4d x=1366 y=0 mode=0x000000f8 rr=Rotate_0 outputs=0x0000004a;
000:<:0031: 20: RANDR-Request(140,7): SetScreenSize window=0x000000d9 width=2049 height=768 width[mm]=538 height[mm]=202
000:<:0032: 56: RANDR-Request(140,26): SetCrtcTransform crtc=0x00000040 transform={matrix=0.500000,0.000000,0.000000,0.000000,0.500000,0.000000,0.000000,0.000000,1.000000;}; filter name='bilinear' filter params=;
000:<:0033: 32: RANDR-Request(140,21): SetCrtcConfig crtc=0x00000040 timestamp=0x00000000 config timestamp=0x00010a4d x=1366 y=0 mode=0x000000f8 rr=Rotate_0 outputs=0x0000004a;
000:>:0033:32: Reply to SetCrtcConfig: status=Success(0x00)
$ tail /var/log/Xorg.0.log
##1st
[ 6644.557] (II) intel(0): resizing framebuffer to 1726x768
[ 6644.560] (II) intel(0): switch to mode 720x400@70.1 on VGA1 using pipe 1, position (1366, 0), rotation normal, reflection none
[ 6660.882] (II) intel(0): switch to mode 1366x768@59.8 on VGA1 using pipe 1, position (1366, 0), rotation normal, reflection none
##2nd
[ 6804.638] (II) intel(0): resizing framebuffer to 2732x768
[ 6804.647] (II) intel(0): switch to mode 1366x768@59.8 on VGA1 using pipe 1, position (1366, 0), rotation normal, reflection none
[ 6817.753] (II) intel(0): resizing framebuffer to 2049x768
[ 6817.757] (II) intel(0): switch to mode 1366x768@59.8 on VGA1 using pipe 1, position (1366, 0), rotation normal, reflection none
Remarkable cases from other questions
##xrandr: Failed to get size of gamma for output default
Driver support or No drive loaded issue, this is famous with nomodeset and old graphics. xrandr does not work well without KMS. Indicators:
sudo lshw -c display could be *-display UNCLAIMED also driver= empty.
maximum 1920 x 1080 buffer size is exactly screen size as minimum, most graphics now are maximum 8192 x 8192, maximum 16384 x 16384 or even 32Kx32K.
- No regular name of connection
default!
- An OpenGL software renderer is used, check
glxinfo, example: Gallium3D/llvmpipe.
To reproduce similar issue
Create a Ubuntu virtualbox without installing the guest additions/modules (which includes vbox graphics driver). It will be very slow and same happen with real machine.
##X Error of failed request: BadMatch (invalid parameter attributes) (RRQueryOutputProperty)
A wrong property name used with xrandr --output .. --set <name> <value>, user should check first for available properties using xrandr --prop. Same case solved here:
Cannot change brightness in laptop
Available properties depend on the used driver and adapter, so it could be also a result from previous case (driver issue), as no properties declared to xrandr.
xrandr --output <connection-name> --set whatever 0
##X Error of failed request: BadMatch (invalid parameter attributes) (RRAddOutputMode)
My current theory, planning to test later when I have time. documented it here. so I don't forget and others may give some feedback.
Error produced with xrandr .. --addmode when the driver refuse it, due to EDID validation. nvidia driver drops some modes, I noticed that after enabling the "ModeDebug". Either:
- EDID data from monitor are not perfect
- Drivers not robust in processing EDID
- The generated mode entry is not in monitor range declared in EDID
Cases (1 & 2) solution is custom override of Hsync/Vsync/PixelClock or complete local EDID file, some drivers can ignore EDID.
Case (3) solution is to try different mode entry. Notice the difference
$ cvt 1280 800 60
# 1280x800 59.81 Hz (CVT 1.02MA) hsync: 49.70 kHz; pclk: 83.50 MHz
Modeline "1280x800_60.00" 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync
$ gtf 1280 800 60
1280x800 @ 60.00 Hz (GTF) hsync: 49.68 kHz; pclk: 83.46 MHz
Modeline "1280x800_60.00" 83.46 1280 1344 1480 1680 800 801 804 828 -HSync +Vsync
reduce mode only for flat monitors
$ cvt -r 1280 800 60
1280x800 59.91 Hz (CVT 1.02MA-R) hsync: 49.31 kHz; pclk: 71.00 MHz
Modeline "1280x800R" 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync
Some cases resolved by just changing the vsync little bit lower, for example 1280 800 59.80. Then if dual monitors are used with different vsync's, probabaly see a cyclic behaivior in one screen (like going blank for 3sec every 15min). This is due that 0.2Hz diffirence from other screen if it uses standard 60Hz. Anyway, this issue may be already vanished with new adanced multi-head adapters and 4K screens. Solutions: Change to exact frequency supported be all connected monitors, remove uncompatibe monitor. (Root cause, may be some cheap monitor chips are desgined for TV)
