Two issues after the upgrade:
- After login in Unity session, a dialog error appears, saying
required virtual size does not fit available size: requested=(1,1), minum=(320,200), maximum=(8192,8192)
I'd like to know what is asking the requested size (1,1) but don't know where to search... Anyway, I can work quite normally, but (don't know if it's related):
- No global keyboard shortcuts work (such as volumeUp/Down, Super-L to block screen, etc.). Local shortcuts (such as Ctrl-Space to open my favourite launcher) work.
Before the upgrade none of the issues occurred.
# sudo dmidecode -s system-product-name; echo ==; lshw -c display; echo ==; xrandr --verbose
M14xR1
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:34 memory:d2400000-d27fffff memory:c0000000-cfffffff ioport:7000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
LVDS-1 connected primary 1366x768+0+0 (0x46) normal (normal left inverted right x axis y axis) 309mm x 174mm
Identifier: 0x41
Timestamp: 38251
Subpixel: horizontal rgb
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0030e4920200000000
00150103901f11780a8e359358569029
20505400000001010101010101010101
010101010101121b5668500012302020
350035ae1000001a121b566850001230
2020350035ae1000001a000000fe0039
4d364452803134305748320a00000000
00004131940100000001010a202000e1
scaling mode: Full aspect
supported: Full, Center, Full aspect
link-status: Good
supported: Good, Bad
1366x768 (0x46) 69.300MHz +HSync -VSync *current +preferred
h: width 1366 start 1398 end 1430 total 1470 skew 0 clock 47.14KHz
v: height 768 start 771 end 776 total 786 clock 59.98Hz
1360x768 (0x47) 84.750MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.72KHz
v: height 768 start 771 end 781 total 798 clock 59.80Hz
1360x768 (0x48) 72.000MHz +HSync -VSync
h: width 1360 start 1408 end 1440 total 1520 skew 0 clock 47.37KHz
v: height 768 start 771 end 781 total 790 clock 59.96Hz
1024x768 (0x49) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x4a) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
960x720 (0x4b) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x4c) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x4d) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
960x600 (0x4e) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
960x540 (0x4f) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
800x600 (0x50) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x51) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x52) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0x53) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0x54) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
800x512 (0x55) 51.562MHz +HSync +VSync DoubleScan
h: width 800 start 800 end 828 total 832 skew 0 clock 61.97KHz
v: height 512 start 512 end 514 total 515 clock 60.17Hz
700x525 (0x56) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
640x512 (0x57) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
720x450 (0x58) 53.250MHz -HSync +VSync DoubleScan
h: width 720 start 760 end 836 total 952 skew 0 clock 55.93KHz
v: height 450 start 451 end 454 total 467 clock 59.89Hz
640x480 (0x59) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0x5a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
680x384 (0x5b) 42.375MHz -HSync +VSync DoubleScan
h: width 680 start 716 end 784 total 888 skew 0 clock 47.72KHz
v: height 384 start 385 end 390 total 399 clock 59.80Hz
680x384 (0x5c) 36.000MHz +HSync -VSync DoubleScan
h: width 680 start 704 end 720 total 760 skew 0 clock 47.37KHz
v: height 384 start 385 end 390 total 395 clock 59.96Hz
576x432 (0x5d) 40.810MHz -HSync +VSync DoubleScan
h: width 576 start 608 end 668 total 760 skew 0 clock 53.70KHz
v: height 432 start 432 end 434 total 447 clock 60.06Hz
512x384 (0x5e) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
400x300 (0x5f) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0x60) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
320x240 (0x61) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
VGA-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x42
Timestamp: 38251
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
link-status: Good
HDMI-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 38251
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 38251
Subpixel: unknown
Clones:
CRTCs: 0 1
filter:
audio: auto
link-status: Good
