I followed the instructions in the answer of
Dell XPS 13 (9350) Compatibility
to solve the problem of not-working wifi (broadcom BCM4350) on my Dell XPS 13 (9350) with fresh installed Ubuntu 15.10.
After unzipping I follow the commands detailed in the answer. The first
sudo chown root:root brcmfmac4350-pcie.bin BCM-0a5c-6412.hcd
returns
chown: changing ownership of 'brcmfmac4350-pcie.bin': Operation not permitted
chown: changing ownership of 'BCM-0a5c-6412.hcd': Operation not permitted
The following command line
sudo mv -t /lib/firmware/brcm/ BCM-0a5c-6412.hcd brcmfmac4350-pcie.bin
works fine, while
sudo dpkg -i linux-headers-4.3.0-wifitest-custom_4.3.0-wifitest-custom-10.00.Custom_amd64.deb linux-image-4.3.0-wifitest-custom_4.3.0-wifitest-custom-10.00.Custom_amd64.deb
returns
Error! Your kernel headers for kernel 4.3.0-wifitest-custom cannot be found. Please install the linux-headers-4.3.0-wifitest-custom package, or use the --kernelsourcedir option to tell DKMS where it's located
Any help is appreciated since I'm a real noob concerning Linux.
bruco
  • 343
This adapter is not supported by Ubuntu stable kernels.
A way to get it work is to install a 4.4 kernel from Ubuntu 16.04 branch.
Connect to internet by wire and run in terminal
mkdir linux-4.4
cd linux-4.4
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux/linux-image-4.4.0-8-generic_4.4.0-8.23_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux/linux-image-extra-4.4.0-8-generic_4.4.0-8.23_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux/linux-headers-4.4.0-8-generic_4.4.0-8.23_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux/linux-headers-4.4.0-8_4.4.0-8.23_all.deb
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.156_all.deb
sudo dpkg -i *.deb
Then reboot and test the wifi.
The kernel files are a subject of updates. The links will need to be updated. Ubuntu packages search can be used to get the correct links
Update: For Ubuntu 14.04 users the 4.4 kernel can be installed by
sudo apt-get install linux-generic-lts-xenial
But dkms packages will not build with this kenel, if gcc 4.9+ is not installed.
Pilot6
  • 92,041
I have just installed the kernel v4.5 from http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.5-wily/ on my Dell XPS 13 (9350) and wifi works fine now. Previously I had kernel v4.2, and tried installing v4.4 rc6 and rc7 without success (couldn't even start Ubuntu after the install).
Steps to follow:
mkdir /tmp
cd /tmp
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.5-wily/linux-headers-4.5.0-040500-generic_4.5.0-040500.201603140130_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.5-wily/linux-headers-4.5.0-040500_4.5.0-040500.201603140130_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.5-wily/linux-image-4.5.0-040500-generic_4.5.0-040500.201603140130_amd64.deb
sudo dpkg -i *.deb
reboot
