How do you fix unmet dependency when installing Cinnamon on Ubuntu 14.04?
I attached a bunch of info on what I've tried so far.
Attempt 1:
So I found this question on how-to install cinnamon on ubuntu 14.04. I tried the first ppa repository and it failed with "unmet dependency... cinnamon-screensaver".
Attempt 2:
I then used ppa-purge to get rid of that repository. Then did apt-get clean. Then I tried the second ppa repository in the how-to guide. I tried to install cinnamon again... and it failed the same way:
root@wheaton-ubuntu14:~# apt-get install cinnamon
Reading package lists... Done
Building dependency tree
cinnamon : Depends: cinnamon-screensaver (>= 2.6.0) but it is not going to be installed
Attempt 3:
I then looked up how to fix unmet dependencies and found this guide with 300+ upvotes so I thought I was all set!
Attempt 4:
I then saw someone was successful with aptitude install cinnamon. But every time aptitude said "is this solution acceptable" cinnamon was still marked as "not installed". So I interrupted the interactive process.
Attempt 5:
I google'd the error and saw a debian thread somewhere with "oh there's a bug fix in git." but then the thread ends with "oh thanks" but no instructions on how to fix the issue.
Not sure where to go from here.
update - as per a request in the comments here is the requested info:
root@wheaton-ubuntu14:~# lsb_release -a; uname -a; apt-cache policy cinnamon cinnamon-screensaver; apt-get install cinnamon-screensaver
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.1 LTS
Release: 14.04
Codename: trusty
Linux wheaton-ubuntu14 3.13.0-66-generic #108-Ubuntu SMP Wed Oct 7 15:20:27 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
cinnamon:
Installed: (none)
Candidate: 2.6.12ubuntu1
Version table:
2.6.12ubuntu1 0
500 http://ppa.launchpad.net/lestcape/cinnamon/ubuntu/ trusty/main amd64 Packages
cinnamon-screensaver:
Installed: (none)
Candidate: 2.6.4ubuntu1
Version table:
2.6.4ubuntu1 0
cinnamon-screensaver : Depends: gir1.2-webkit2-3.0 but it is not going to be installed
update 2 - another request from A.B user: see here
