I have been trying to install cinnamon in my ubuntu 13.04 and when i give
sudo apt-get install cinnamon
I get the error as:
 cinnamon : Depends: libgjs0-libmozjs185-1.0
        Recommends: nemo but it is not going to be installed
        Recommends: cinnamon-screensaver but it is not going to be installed
Aswin Murugesh
  • 121
This happened to me when I had already install Gnome onto ubuntu.
After install Aptitude and using it to install, it gave me the option to downgrade Gnome in order to install Cinnamon. If you do this Cinnamon should install.
$ sudo apt-get install aptitude
$ sudo aptitude install cinnamon
[sudo] password for <USER>:
The following NEW packages will be installed:
  cinnamon{b} gir1.2-muffin-3.0{a} libmuffin0{a} muffin-common{a}
0 packages upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,255 kB of archives. After unpacking 9,065 kB will be used.
 cinnamon : Depends: libgjs0-libmozjs185-1.0 which is a virtual package.
            Depends: libmozjs185-1.0 (>= 1.8.5-1.0.0+dfsg) but it is not going to be installed.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     cinnamon [Not Installed]
Accept this solution? [Y/n/q/?] n
     Install the following packages:
1)     libmozjs185-1.0 [1.8.5-1.0.0+dfsg-4 (raring)]
     Downgrade the following packages:
2)     gjs [1.36.1+js17-0ubuntu1~raring0 (now, raring) -> 1.34.0-0ubuntu1 (raring)]
3)     gnome-shell [3.8.1-0ubuntu1~raring1.2 (now, raring) -> 3.6.3.1-0ubuntu6 (raring)]
4)     gnome-shell-common [3.8.1-0ubuntu1~raring1.2 (now, raring) -> 3.6.3.1-0ubuntu6 (raring)]
5)     gnome-sushi [3.8.0-1~ubuntu13.04.2 (now, raring) -> 3.6.1-0ubuntu1 (raring)]
6)     libgjs0c [1.36.1+js17-0ubuntu1~raring0 (now, raring) -> 1.34.0-0ubuntu1 (raring)]
Accept this solution? [Y/n/q/?] y
The following packages will be DOWNGRADED:
  gjs gnome-shell gnome-shell-common gnome-sushi libgjs0c
  cinnamon gir1.2-muffin-3.0{a} libmozjs185-1.0{a} libmuffin0{a} muffin-common{a}
0 packages upgraded, 5 newly installed, 5 downgraded, 0 to remove and 0 not upgraded.
Need to get 4,992 kB of archives. After unpacking 12.4 MB will be used.
Do you want to continue? [Y/n/?] y
you will have to input the 'n' and two 'y's in order to install.
daboross
  • 2,203
This is a relatively easy fix, at least an easy one to try! :) It appears you have a broken dependency/package, an easy fix.
Do this:
sudo apt-get clean && sudo apt-get update
It should fix your broken packages error, then you can run the sudo apt-get install cinammon command to install it!
Good Luck!
slm
  • 3,155
The issue seems to be with the pin priority with the PPA. This should fix the issue.
Open the preferences file:
    gksu gedit /etc/apt/preferences
Then add this at the bottom:
    Package: *
    Pin: origin ppa.launchpad.net
    Pin-Priority: 700
Save and close the file and open your terminal to update your packages then install cinnamon.
    sudo apt-get update && sudo apt-get install cinnamon
That should work.
I have switched to Linux Mint 15 for my personal distro choice and this is what I had to do to get the latest release of cinnamon and nemo on my machine.
