I have a script that updates my desktop background every day with the NASA APOD. Since upgrading to 11.10, that script stopped working, presumably because I'm using gconftool-2 to actually update the desktop background. Is there a new way to do this under Unity?
- 107,582
- 1,015
Gnome Shell (Gnome 3) uses GSettings now instead of GConf. So in Gnome Shell you can use the command-line tool gsettings for that. Like gconftool, it lets you get or set an individual key.
You can get the current URI of the background image as follows:
gsettings get org.gnome.desktop.background picture-uri
'file:///home/serrano/Pictures/x.jpg'
And set the background URI as follows (which will immediately update your desktop background):
gsettings set org.gnome.desktop.background picture-uri file:///home/serrano/Pictures/y.jpg
Notice that you must prepend the URI with "file://" for this to work (unlike with gconftool).
Ubuntu 22.04 and later
Since Ubuntu 22.04 the behavior has changed a little, depending on your color scheme preference:
gsettings get org.gnome.desktop.interface color-scheme
If your color-scheme is "prefer-dark" use picture-uri-dark instead:
gsettings set org.gnome.desktop.background picture-uri-dark file:///home/serrano/Pictures/y.jpg
Otherwise use picture-uri like before:
- 2,022
This code randomly changes the wallpaper from a given directory.
#!/bin/bash
DIR="/home/indra/Pictures/wallpapers"
PIC=$(ls $DIR/* | shuf -n1)
gsettings set org.gnome.desktop.background picture-uri "file://$PIC"
Save this script and edit your with the command "crontab -e" (it launches an editor where you put this line at the end of the file):
*/1 * * * * /bin/bash /path/to/script.sh
Introduction
This answer is an edit of the original answer. As I've progressed in my Ubuntu and Linux studies, I've discovered a variety of approaches and deepened my understanding of how setting a background works in Ubuntu. This answer is my attempt to document as best as possible what I've learned thus far, and is done in hopes that this material can be useful for others.
The important part is that to set background for Unity desktop from command line, you can use
gsettings set org.gnome.desktop.background picture-uri 'file:///home/JohnDoe/Pictures/cool_wallpaper.jpg'
Setting background in Unity vs bare X desktop
The way Unity works is such that there is bare X desktop below, and above there is Unity's desktop window (which in fact is a special instance of Nautilus's window , the default file manager of Ubuntu ). Thus, when you call
that sets background for that special Nautilus window. When you disable desktop icons with
gsettings set org.gnome.desktop.background show-desktop-icons false
that will kill the Nautilus desktop and show you bare-bones X desktop. For the bare-bone X desktop you can use feh program. Particularly, this command:
feh --bg-scale /home/JohnDoe/Pictures/cool_wallpaper.jpg
There's also GUI alternative to that, nitrogen. The feh and nitrogen approaches can be used with desktops other than Unity, such as openbox or blackbox. The gsettings approach can be used with Unity or other GNOME-based desktop.
Disecting the gsettings command
What exactly does gsettings command do ? Well, first of all, there exists dconf database of settings for each user, which is intended as replacement for deprecated GConf, and it is accessible via either dconf command or gsettings. In particular , we're dealing here with
org.gnome.desktop.background schema and one of its keys, picture-uri.
URI, that file:///home/JohnDoe/Pictures/cool_wallpaper.png, actually stands for Uniform Resource Identifier, which originally was created for internet usage, but there is file URI scheme , which is what we see here. What's cool about URI is that it gives byte-encoded path if you use a non-english locale, for example with my Chinese desktop, I have following URI for my backgroun: 'file:///home/xieerqi/%E5%9B%BE%E7%89%87/Wallpapers/moon_moon.jpg'
Scripting with gsettings
Of course, writing out the command each time is tedious and one can use a little bit of scripting magic. For instance, here's what I have set in my ~/.bashrc so that I can change background at will:
change_background() {
FILE="'file://$(readlink -e "$1" )'"
if [ "$FILE" != "'file://'" ]
then
gsettings set org.gnome.desktop.background picture-uri "$FILE"
else
echo "File doesn't exist"
fi
This function can be called with absolute path such as
change_background /home/JohnDoe/Pictures/cool_wallpaper.jpg
or with relative path from current working directory
change_background Pictures/cool_wallpaper.jpg
It also performs a check if file exists and resolves symlinks. This can be used in a shell script or as standalone function for daily use.
Of course, this is not the only way. Python has an API for Gio ( which is the main library behind gsettings ). I've written a gsettings_get and gsettings_set functions, which were quite useful for other projects such as Launcher List Indicator. In case of setting a background, it can also be used and I've used it just recently for this question. Here's a simplified version of that same approach:
#!/usr/bin/env python3
Author: Serg Kolo , <1047481448@qq.com>
Date: December, 21,2016
Purpose: script for setting wallpaper, the pythonic way
Written for: https://askubuntu.com/q/66914/295286
from gi.repository import Gio
import os,sys,random
def gsettings_set(schema, path, key, value):
"""Set value of gsettings schema"""
if path is None:
gsettings = Gio.Settings.new(schema)
else:
gsettings = Gio.Settings.new_with_path(schema, path)
if isinstance(value, list):
return gsettings.set_strv(key, value)
if isinstance(value, int):
return gsettings.set_int(key, value)
if isinstance(value,str):
return gsettings.set_string(key,value)
def error_and_exit(message):
sys.stderr.write(message + "\n")
sys.exit(1)
def main():
gschema='org.gnome.desktop.background'
key='picture-uri'
if len(sys.argv) != 2:
error_and_exit('>>> Path to a file is required')
if not os.path.isfile(sys.argv[1]):
error_and_exit('>>> Path "' + sys.argv[1] + \
'" isn\'t a file or file doesn\'t exit')
full_path = os.path.abspath(sys.argv[1])
uri = Gio.File.new_for_path(full_path).get_uri()
gsettings_set(gschema,None,key,uri)
if __name__ == '__main__': main()
Of course, same rules for scripts apply here too: ensure it is made executable with chmod +x set_wallpaper.py and store it in (preferrably) ~/bin folder. Usage is simple: ./set_wallpaper.py Picture/cool_image.py Source code of this script is also available on my GitHub repository with many other scripts,too.
- 185
- 107,582
In Ubuntu 22.04 there are two different images/commands for light and dark theme:
Dark theme (picture-uri-dark):
gsettings set org.gnome.desktop.background picture-uri-dark file:///home/Pictures/image.jpg
Light theme (picture-uri):
gsettings set org.gnome.desktop.background picture-uri file:///home/Pictures/image.jpg
- 383
Also you can use this:
dconf write "/org/gnome/desktop/background/picture-uri" "'file:///home/YOUR_USER/bg.png'"
- 21
Thanks to Serrano's awesome answer, I was able to write this script which I use as part of my new machine setup scripts to set a black background:
#! /bin/bash
SRC_URI="https://i.imgur.com/uomkVIL.png"
FNAME="/home/$USER/Pictures/black.png"
wget "$SRC_URI" -O "$FNAME"
gsettings set org.gnome.desktop.background picture-uri "$FNAME"
- 140
