I wanted to make a bash script that takes a random picture from a folder and sets it as the desktop background. I figured out the algorithm (it's not hard) but I can't find a command that would change the background picture if you give it the path to the picture.
I found gconftool for bash 2.~ and gsettings for bash 3.~, but i have GNU bash, version 4.3.42(1)-release on Ubuntu 16.04 LTS and these don't work.
Zanna
  • 72,312
someoneb100
  • 179
Assuming you're using standard Ubuntu 16.04 with Unity, you can use the following command to set the wallpaper:
gsettings set org.gnome.desktop.background picture-uri "file:///home/username/path/to/image.jpg"
You should also look at Variety wallpaper changer - it does the same thing as what you want to do with a shell script, with a lot of features and options.
Jonas Czech
  • 4,047
I've done it like this:
targetDir="/home/username/Photos"
function get_next_photo() {
    # Returns a random file form targetdir
    files=( "$targetDir"/* )
    echo "${files[RANDOM % ${#files[@]}]}"
function set_background() {
    # Takes an absolute file path as argument. Need * for spaces in path
    bg="$*"
    echo "Setting background to $bg"
    gsettings set org.gnome.desktop.background picture-uri "file://$bg"
background=$(get_next_photo)
echo "Next background is $background"
set_background $background
Then add a quick launcher for your script to the dock, and you can change your wallpaper in one click.
MathKid
  • 131
