113
I keep hearing about these things known as tty's.
  • what are they
  • how can I access them
  • what do they do?
jrg
  • 61,707
5 Answers5
112
tty is one of those funky Unix commands that prints the name of the terminal connected to standard input.
TTY's are text-only terminals commonly used as a way to get access to the computer to fix things, without actually logging into a possibly b0rked desktop.
Related: What is tty7 in the commandline?
By default, Ubuntu has 7 tty's.
  • On Ubuntu 17.10 and newer: It's GUI login screen on 1, GUI desktop on 2 and command lines on 3-7.
  • Up until Ubuntu 17.10: 1-6 are command line only and 7 runs your X session (your normal desktop).
To access them, use this keyboard shortcut:
Ctrl + Alt + F3 (or F1 until 17.10).
Changing F3 to F3-F6 to access the terminal that you want.
To get back to your GUI session (the normal desktop):
Ctrl + Alt + F2 (or F7 until 17.10).
Pablo Bianchi
  • 17,371
jrg
  • 61,707
10
A tty, short for teletype and perhaps more commonly called a terminal, is a device which lets you interact with the system by sending and receiving data, such as commands and the output they produce.
There are many kind of ttys, but nowadays most ttys are implemented in software, such as the graphical consoles you can access with Ctrl+Alt+Fn, or terminal emulators such as Gnome terminal that run inside an X session.
There is also a tty command, which shows the device node of the terminal in which it is running (or prints "not a tty" if it is not running inside a terminal; yes, it is possible to run commands outside a terminal). For example:
firas@itsuki ~ % tty
/dev/pts/0
firas@itsuki ~ % ssh localhost tty
not a tty
When I am logged in and running a shell on the machine, the shell is normally running inside a terminal, namely here it is /dev/pts/0. However, when I run ssh host command to run a command on a remote host, the command is not run inside a terminal.
fkraiem
  • 12,813
You can change the displayed TTY by commmand line with chvt (requires sudo privileges), from SSH for example. Here is the relevant part of the manpage (man chvt):
CHVT(1)
NAME
chvt - change foreground virtual terminal
SYNOPSIS
chvt N
DESCRIPTION
The command chvt N makes /dev/ttyN the foreground terminal. (The corresponding screen is created if it did not exist yet. To get rid of unused VTs, use deallocvt) The key combination (Ctrl-)LeftAlt-FN (with N in the range 1-12) usually has a similar effect.
JulienBu
  • 41
AFAIK, on a decent functioning machine there is no difference (except there are colors in the desktop terminals, and you can minimize them and other little reasons they're easier)
HOWEVER, if you are trying to use an old laptop with < 4GB of RAM, or you messed up your debian install (still not sure, anyone stable on Dell inspiron 11-3162?); then the tty's will work when the desktop is lagging or malfunctioning or forgetting how to write a "d" for some reason: The ttys just work, and respond quickly. There is no press a button and wait 30 seconds to see it show up (if the desktop terminal even decides to behave at all) it just works.
ALSO just tested, nano still color codes in tty's, I'm sure vim or whatever you guys are into will as well.
THE other posts already showed you how to use them, it seemed you were confused as to why as well. This is the reason for my answering as I did; hope it helps.
EDIT also, it appears launching web pages from tty's is much more difficult than the simple one liner two string command from a terminal open in a gui
Tl;DR Gui terminals have more features and are easier in some ways but when the gui is buggy the tty's terminals work more quickly and efficiently.
It changes your workspace: for example, you could have a text file open and change to tty2 then you might have a /ls command for reference. This is very helpful for an environment like Ubuntu Server.
This is the equivalent of having two tabs open in a GUI Environment.
In Ubuntu Server (16.04.3 LTS - for me) I can use ALT+F1-F6 or use ALT+LeftArrow to go back a number or ALT+RightArrow to go forwards a number.
You can see your tty by logging out from Ubuntu Server (run logout) and see up at the top Ubuntu 16.04.3 LTS ubuntu tty# that is standard, but may differ from version to version.
If your tty isn't shown on your login screen then you can run sudo nano /etc/issue and at the top, you can put in whatever you like but to add the tty you need to place \l. Place \n for the hostname.
Example:
/etc/issue
Ubuntu 16.04.3 LTS \n \l
would show
Notes:
# refers to a number
