29
Recently I have been playing around in terminal and typed the who command. As I see my username and date, I don't know what tty7 (tty2 on Ubuntu 17.10 and newer) or what this pts/0 is, can somebody explain this to me?
Pablo Bianchi
  • 17,371
Fusky
  • 405
The name of TTY actually comes from the old days of computers: then computers even had teletypewriters as terminal, so you could see the output of programs printed (tty = TeleTYpe/TeleTYpewrite).
TTY usually refers for "physical" terminals, like more attached terminals (even like a teletypewriter) to a single computer, or in our days: more separated text consoles, you can switch between them Ctrl + Alt + F1-F7 (or more, if you have configured more; F3-F6 on Ubuntu 17.10 and newer).
In case of Ubuntu, tty7 is usually used by Xorg/Wayland display server, do provide your graphical environment (to be more exact, it provides a "windowing system" only, and things like the gnome - as a desktop environment solution - runs "top of it").
By contrast, "pts" is (one half of) a notion of "pseudo terminal" which implements terminal functionality without the context of a "real" physical terminal, for example if you open gnome-terminal, for the shell (which is usually the bash on Ubuntu systems) to be able to run, it needs terminal capabilities.
This is also the case if you use "ssh" to log in a remote machine, so in nutshell: whenever something needs terminal/tty like functionality without having a 'real' tty.
Pablo Bianchi
  • 17,371
LGB
  • 1,567
I think usually it's the display server (X server).
Press Ctrl+Alt+F7 (F3 on Ubuntu 17.10 and newer) and see if it takes you to your graphical login session (or keeps you there).
You can also open a shell and run tty. It will tell you the name of your current terminal.
Pablo Bianchi
  • 17,371
Mikel
  • 6,615
tty7 is the physical terminal from which you logged in. In many cases, tty7 is where your window manager runs and from which you login.
As can be seen from the listing below, I logged in at 9:33 on May 24 from tty7 (via Gnome window manager login dialog) and then opened 4 pseudo terminals.
[iluvblender@myhome ~]$ last | tac | egrep "May\s*24"
sgoda    tty7         :0               Wed May 24 09:33   still logged in
sgoda    pts/0        :0               Wed May 24 09:33   still logged in
sgoda    pts/2        :0               Wed May 24 09:36   still logged in
sgoda    pts/4        :0               Wed May 24 09:40   still logged in
sgoda    pts/5        :0               Wed May 24 09:42   still logged in
