I have recently upgraded to Ubuntu 14.04 LTS 64-bit. I had this configuration working for three years with Ubuntu 12.04 LTS. I went for a fresh installation (not distro upgrade), the only thing I kept are the home folders (/home mountpoint) of my users. Scenario:
- I can access my wi-fi network
- I can stream music via bluetooth with A2DP
If I try to do both at the same time now, e.g stream audio from deezer, the internet connection stops. I can't even ping google.com; so I think this is not a browser related issue. If I switch-off the bluetooth everything gets back to normal. I've got no clue on where to start debugging my problem.
Here the output of lspci -knn | grep Net -A2; lsusb
03:00.0 Network controller [0280]: Intel Corporation Centrino Wireless-N 1030 [Rainbow Peak] [8086:008a] (rev 34) Subsystem: Intel Corporation Centrino Wireless-N 1030 BGN [8086:5305] Kernel driver in use: iwlwifi
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 1bcf:2883 Sunplus Innovation Technology Inc.
Bus 001 Device 003: ID 8086:0189 Intel Corp.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
