They successfully connect via bluetooth and when I test the sound from the settings, both sides work. However, when I try to listen to something on the internet (with firefox), I hear nothing.
I tried the solutions to this question, they didn't work. I also tried using alsamixer - Master is currently set to 100, Headphone to 78, and PCM to 85 - still doesn't work.
Any suggestions would be appreciated.
This is most likely not a problem with your headphones but the app.
Go to Settings > Sound > Applications > check the sound level for Firefox
Also try other apps like Rhythmbox or something, see if that works. If it does then you've narrowed down the problem specifically to your browser.
https://gist.github.com/pylover/d68be364adac5f946887b85e6ed6e7ae script may help you. But it's not tested on 18.04, please let me know if worked.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
iRhonin
  • 111
