I try to solve a problem of mine and I have some difficulties. I can't install/remove/dist-upgrade/clean/autoclean any package. When I try to run sudo apt-get -f install to fix unmet dependencies I get:
orian@orian-desktop:~$ sudo apt-get -f install
[sudo] password for orian:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
cpp-4.8-arm-linux-gnueabihf cpp-arm-linux-gnueabihf dh-apparmor diffstat
gcc-4.8-arm-linux-gnueabihf-base gettext intltool-debian lib32asan0
lib32atomic1 lib32gcc1 lib32gomp1 lib32itm1 lib32quadmath0 lib32stdc++6
libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl
libapt-pkg-perl libarchive-zip-perl libasan0 libasan0-armhf-cross
libasprintf-dev libatomic1 libatomic1-armhf-cross libauthen-sasl-perl
libautodie-perl libbonobo2-common libbonoboui2-common
libc6-armel-armhf-cross libc6-armel-cross libc6-armhf-cross
libc6-dev-armel-armhf-cross libc6-dev-armel-cross libc6-dev-armhf-cross
libclass-accessor-perl libclone-perl libcloog-isl4 libdigest-hmac-perl
libdpkg-perl libemail-valid-perl libfile-fcntllock-perl libfs6
libgcc-4.8-dev libgcc-4.8-dev-armhf-cross libgcc1-armhf-cross
libgettextpo-dev libgettextpo0 libglade2-0 libgnome2-common
libgnomecanvas2-0 libgnomecanvas2-common libgnomeui-common
libgomp1-armhf-cross libio-pty-perl libio-socket-inet6-perl
libio-socket-ssl-perl libio-string-perl libipc-run-perl
libipc-system-simple-perl libisl10 libitm1 liblist-moreutils-perl
libmail-sendmail-perl libmailtools-perl libmpc3 libmpfr4 libnet-dns-perl
libnet-domain-tld-perl libnet-ip-perl libnet-libidn-perl
libnet-smtp-ssl-perl libnet-ssleay-perl liborbit-2-0
libparse-debianchangelog-perl libperlio-gzip-perl libquadmath0
libsfasan0-armhf-cross libsfatomic1-armhf-cross libsfgcc-4.8-dev-armhf-cross
libsfgcc1-armhf-cross libsfgomp1-armhf-cross libsfstdc++-4.8-dev-armhf-cross
libsfstdc++6-armhf-cross libsocket6-perl libstdc++-4.8-dev
libstdc++-4.8-dev-armhf-cross libstdc++6-armhf-cross libsub-identify-perl
libsub-name-perl libsys-hostname-long-perl libtext-levenshtein-perl
libtimedate-perl libtsan0 liburi-perl linux-headers-3.16.0-30
linux-headers-3.16.0-30-generic linux-image-3.16.0-30-generic
linux-image-extra-3.16.0-30-generic linux-libc-dev-armel-cross
linux-libc-dev-armhf-cross patchutils po-debconf t1utils x11-xfs-utils xinit
xorg-docs-core
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libc6-dev-amd64:i386
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 9 not upgraded.
16 not fully installed or removed.
Need to get 0 B/1,429 kB of archives.
After this operation, 9,590 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 244830 files and directories currently installed.)
Preparing to unpack .../libc6-dev-amd64_2.19-0ubuntu6.6_i386.deb ...
Unpacking libc6-dev-amd64 (2.19-0ubuntu6.6) ...
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-amd64_2.19-0ubuntu6.6_i386.deb (--unpack):
trying to overwrite '/usr/include/gnu', which is also in package libc6-dev-i386 2.19-0ubuntu6.6
I tried this How do I resolve unmet dependencies after adding a PPA? but I get the same error. please help me. thanks a lot, Orian.
EDIT: When I try to run sudo apt-get autoremove I get:
orian@orian-desktop:/boot$ sudo apt-get autoremove
You might want to run 'apt-get -f install' to correct these.
gcc-4.8-multilib:i386 : Depends: libc6-dev-amd64:i386 (>= 2.11) but it is not installed
libc6-dev-x32:i386 : Depends: libc6-dev-amd64:i386 (= 2.19-0ubuntu6.6) but it is not installed
E: Unmet dependencies. Try using -f.
and for uname -mr:
orian@orian-desktop:/boot$ uname -mr
3.16.0-39-generic x86_64
I think you are affected by an already reported bug in libc6-dev. There seems to be no fix provided, but one workaround (provided in Comment #4 and possibly #5 also) is to remove that package completely by:
sudo apt-get purge libc6-dev-amd64
sudo apt-get clean
sudo apt-get install -f
You can also see sudo apt-get -f install fails post
Ron
  • 20,938
