13
I haven't installed any new packages recently or added any PPAs, just ran apt update.
After running 'apt upgrade'
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 libglvnd-dev : Depends: libglvnd0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libglvnd-core-dev (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libegl1 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libgles2 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libgl1 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libglx0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
                Depends: libopengl0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
After running 'apt --fix-broken install' or 'apt-get install -f'
Correcting dependencies... Done
The following additional packages will be installed:
  libgles1 libglvnd-dev
The following NEW packages will be installed:
  libgles1
The following packages will be upgraded:
  libglvnd-dev
1 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/14.6 kB of archives.
After this operation, 66.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 686678 files and directories currently installed.)
Preparing to unpack .../libgles1_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libgles1:amd64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libgles1_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1', which is also in package nvidia-340 340.106-0ubuntu3
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libglvnd-dev:amd64 (1.0.0-2ubuntu2.2) over (1.0.0-2ubuntu2.1) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so', which is also in package nvidia-340 340.106-0ubuntu3
I tried switching back to nouoveau temporarily but due to apt being messed up I can't. The control file asks for all the dependencies to be *-2.2 but when I try to upgrade it's asking for *-2.1.
UPDATE I fixed it by running
sudo dpkg -i --force-overwrite /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb
sudo dpkg -i --force-overwrite /var/cache/apt/archives/libgles1_1.0.0-2ubuntu2.2_amd64.deb
sudo apt -f install
pibacco
  • 291
@pibacco solution on question worked for me:
sudo apt -f install
sudo apt update
sudo apt upgrade
Andres
  • 572
You need to remove packages completely by
sudo dpkg --purge --force-depends "libgles1"
sudo dpkg --purge --force-depends "libglvnd-dev"
sudo apt-get autoremove
sudo apt-get clean
sudo apt-get install -f
You can also see Can't solve unmet dependencies and sudo apt-get -f install fails
