I think I have a problem with mixing different repository packages, but I can't uninstall any of the conflicting packages. Any suggestions?
gunnar@gunnar-VirtualBox:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
libc6-dev-i386
The following NEW packages will be installed:
  libc6-dev-i386
0 upgraded, 1 newly installed, 0 to remove and 107 not upgraded.
4 not fully installed or removed.
Need to get 0 B/1,151 kB of archives.
After this operation, 6,337 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 247223 files and directories currently installed.)
Preparing to unpack .../libc6-dev-i386_2.19-0ubuntu6.5_amd64.deb ...
Unpacking libc6-dev-i386 (2.19-0ubuntu6.5) ...
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-i386_2.19-0ubuntu6.5_amd64.deb (--unpack):
trying to overwrite '/usr/include/gnu', which is also in package libc6-dev-amd64   2.19-0ubuntu6.5
I believe the observed behavior to be a manifestation of the following bug:
https://bugs.launchpad.net/ubuntu/+source/eglibc/+bug/1365375
I provided a workaround in the above-cited bug report, in Comment #4:
https://bugs.launchpad.net/ubuntu/+source/eglibc/+bug/1365375/comments/4
For your convenience, the text of that post is herein reproduced:
To follow-up on my previous comment, I was able to work around this "broken state" in aptitude by purging the offending packages with "--force-depends":
dpkg --purge --force-depends "gcc-multilib"
dpkg --purge --force-depends "lib32z1-dev"
dpkg --purge --force-depends "libc6-dev-x32"
Now, I'm able to use "apt-get" as normal.
Hopefully, this workaround won't cause problems in the future.
Unfortunately, the long-term solution is to await a proper fix from Canonical.
Remove the file /var/cache/apt/archives/libc6-dev-i386_2.19-0ubuntu6.5_amd64.deb and run sudo apt-get -f install again.
You have a 32 bit OS but have libc6-dev-i386_2.19-0ubuntu6.5_amd64.deb file which is a 64 bit .deb file in your /var/cache/apt/archives/. So 32-bit Ubuntu is not being able to unpack it and giving the error. In a nutshell, run the following:
sudo rm /var/cache/apt/archives/libc6-dev-i386_2.19-0ubuntu6.5_amd64.deb
heemayl
  • 93,925
As /usr/include/gnu is being overwritten by file from other package, remove that package will solve your problem.
Run following command to get rid of this situation.
sudo apt-get purge libc6-dev-i386
sudo apt-get autoremove
sudo apt-get clean
sudo apt-get install -f
g_p
  • 19,034
  • 59
  • 69
