I created yesterday a drive image using GZip.
I opened the 51.3 GiB file named ssd.img.gz to see one icon thats a package of 3.9 GiB, yes, thats THree point Nine Gigabytes in size and has the name of the image as ssd.img
That does not seem right to me, has the image creation worked or not?
Yes the drives have data and an operating system on it.
Should I have used cat instead? only I did and it kept on saying that it had nothing to do.
Would using the | zip instead be a better option?
** EDIT **
The command used was:
mark@zotac:~$ sudo -l
Enter password:<entered password to get in to root>
root@zotac:~# dd if=/dev/sda | gzip -c > "/media/mark/Seagate External Drive/ssd.img.gz
the terminal spent the best part of 10 Hours at building the image, something in itself that I also found suspect, why so log when copying the files to a folder that I wanted, some 40GiB took 45 minutes...
The source drive /dev/sda had no mounted partitions.
** EDIT **
Just to clarify, I am trying to make an image of the drive to back up later if things go wrong with a repair, the drive itself needs to be a file on a drive as the target drive partition is using almost all of the drive, the partitions can't be resized on it without formatting it and I am not about to lose 1.4TB of data.
So the dd if=/dev/sda of=/<target> isn't what I need, what I do need is an image of the drive that I can restore the image from to the drive should the repair go wrong.
So what command do I use, dd or cat? Why does | zip keep telling me it has nothing to do when used with cat but no error or warning with dd
If the disk is almost full, there is no sense in compressing the image; it will take ages with no practical effect. And restoring will be much slower too.
dd copies physical, byte-by-byte partitions or disks. It works by reading N bytes from the input and writing them to the output, and then repeating. N is by default 512 bytes.
To copy a disk/partition physically, use
dd bs=10M if=/dev/sda of=/path/to/dest/image.img
this will read blocks of 10Mbytes at a time. If you have plenty of RAM you can up that number too. The size of the file will be exactly the same as the size of the disk/partition used (but it can occupy less disk sometime --- dd can create sparse files).
You can check the progress in another terminal with
ls -lh /path/to/dest/image.img
which will give you the size of the image file (more or less --- it will be in chunks, really).
Triple check (with mount) that no partition of the disk to copy is mounted or used anywhere, or the created image will be invalid (and worst things can happen, too). Be careful about swap areas, too.
You can mount the image to check if it's ok with a loopback filesystem and a bit of tricks.
Anyway, there are also tools that helps the tasks: How to make a disk image and restore from it later?
If your system is not recent (the system from where you are booting, I mean), be warned of this bug --- fixed from 14.04 onward, but still there for older kernels.
Rmano
  • 32,167
Compressing a whole drive's or a partition's image using Gzip may lead to a tremendous reduction in file size but only in case there were no unused data remnants stored and unused space is uniformly filled e.g. by Zeros.
This may be the case for a very new hardly used drive, or for a drive where we had manually filled unused space with Zeros (e.g. using the utility zerofree Install zerofree).
  • This is however not the case for an old used drive where data remnants will be randomly dispersed all over the drive, for a drive where a secure wipe had filled unused space with random numbers, or after a wholde disk encryption. In these cases Gzip will not be able to compress so much or not at all (random numbers can't be compressed).
  • It also is not the case for a SSD used in write mode for some time because on each write all memory blocks will be evenly distributed all over the drive by the drive's firmware to avoid wear leveling. Then any compression of an image will also compress those data remnants which will be more and more random over time.
So, in your case a 3.9 GiB compressed image of a 50 GiB SSD may be possible for a rather new, hardly used drive or a drive mainly used for reading but not for writing much onto it. But then it is a sensible value.
To find out for sure we'd need to decompress the image to compare it's content with the source.
Takkat
  • 144,580
