EDIT: I have reviewed the "Duplicate claim" and to be frank, it is not answering my query, like most of my questions, the existing duplicate question do not answer my query.
Besides that, I am dumping Ubuntu as I am sick and tired of the persistent issues with it, things working one day then not the next and everything breaking after each update and I do believe the main reason I can't update is due to my system being knobbled :)
So enough is enough, I have found a stable version of software that does not contain spyware like Ubuntu does.
Happy smoking guys.
Ciao.
I have asked a couple of times on how to go about this cloning of a drive, I have been advised to use dd or cat but neither work, well dd worked but not as expected. The command I used was:
dd if=/dev/sda | gzip -c > "/media/mark/Seagate Expansion Drive/ssd.img.gz"
The result was an unusually large container (51.3GiB) for a very small image file (3.9GiB) and it took more than 10 hours to do. I was able to copy data from the drives with copy and paste in about 45 Minutes before I unmounted for the drive image to be completed.
So, to set things straight from the outset...
Drive to be copied - SSD drive, 64GB on the tag, has two partitions, is referenced as /dev/sda/ with /dev/sda2 as the boot partition NOT MOUNTED
Drive to have image dumped to - USB HDD, 2TB on the tag, has one partition with 144MB buffer at the end on /dev/sdc1 IS MOUNTED
The drives copied from and copied to are not used as a boot drive, the boot device/partition is on /dev/sdb1 (which is an SD Card) and neither device is used during the process. Yes the sda drive is unmounted, had to repeat that point as the first time around it may have been missed.
Each time I am told that I should use dd if=/dev/sda | gzip -c > "/media/mark/Seagate Expansion Drive/ssd.img.gz" the image results in a very strange file that is 51.3GiB and in that file is a 3.9GiB file thats the image!?!?! Ummm the drives are nearly full!
Each time I try to do this using ZIP which is what I want and thats so I can access in Windows should I need to do a blanket reinstall and pull the files I need from the ZIP file, however when I use dd if=/dev/sda | zip "/media/mark/Seagate Expansion Drive/ssd.img.zip" I get a message that the program has nothing to do!
I have tried the same with the cat command and that results in errors stating that "nothing to do!" and despite pointing out my needs, I get answers that would over write the existing partition, not what I am looking to do.
Yes "I have the ZIP libraries", yes "the drive to write to is mounted", no "the source drive is not mounted", I have no storage issues, so the ZIP can be uncompressed format.
Can someone help please?
** EDIT **
Excuse me for getting frustrated BUT does Ububntu have ANY software that works?
My problem is very simple to follow, I have an SSD that is 64GiB in size, it is about 98% full.
I have followed examples online and by advice from here in askubuntu and everyone posts stuff like I have previously posted.
The image file made using dd resulted in a 51.3GiB file called ssd.img.gz, within that gz archive a file called ssd.img resides and it is 3.9GiB in size.
NOW FORGET ALL THAT ABOUT THE CONTAINER...
I want to make an image of a drive that can later access in a ZIP program, I have gzip and zip libraries, my preference is ZIP because windows can read ZIP files without any external program.
How can I make a useable drive image that I can verify as being the same so I can then repair / break the drive with the confidence that I can restore the contents as it once was.
How can I do that please?
