Please do not mark this as duplicate. I already studied libc6:i386 : Depends: libgcc1:i386 but it is not going to be installed and How do I resolve unmet dependencies after adding a PPA? and tried all their suggestions. Still, I cannot install libc6:i386 and, therefore, cannot run any 32-bit apps on my newly installed Ubuntu 14.04.2 64-bit.
sudo apt-get -f install libc6:i386
Reading package lists... Done
Building dependency tree
sudo apt-get -f install libgcc1:i386
 libgcc1:i386 : Depends: libc6:i386 (>= 2.2.4) but it is not going to be installed
                PreDepends: multiarch-support:i386
sudo apt-get -f install multiarch-support:i386
 multiarch-support:i386 : Depends: libc6:i386 (>= 2.13-5) but it is not going to be installed
I also tried:
sudo apt-get -f install libc6-i386
libc6-i386 : Depends: libc6 (= 2.19-0ubuntu6) but 2.19-0ubuntu6.5 is to be installed
By the way, what's the difference between libc6-i386 and libc6:i386?
cat /etc/apt/sources.list
  (I removed comments)
deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
deb http://extras.ubuntu.com/ubuntu trusty main
deb-src http://extras.ubuntu.com/ubuntu trusty main
cat /etc/apt/sources.list.d/*
  nothing
So, simple question: how to run 32-bit apps on Ubuntu 14.04.2 64-bit?
jhnlmn
  • 167
I had this same issue and after searching the internet over and over nothing seemed to work. Then I noticed the version's being referenced and that the the numbers were off for the version of Ubuntu 2.4.X installed but required 2.6.11??! Pretty fishy!!! So on a very wild shot in the dark and feeling like it was this or a re install I downloaded the latest kernel set and installed it ...POOF issue gone!. I am including a link to the kernel repo. make sure you grab all 3 files of whatever your going with (Master Header, Headers, and image..master header will be the top file in the group). Put all three in there own folder and run a batch dpkg install from the folder. That way the packages are installed in the proper order. Reboot right after, oh and dont get scared and start reading about the patch files... That is only if you are going to compile your own kernel. Not a complicated process like some will have you think. Kernel Repository
