I have download teamviewer.deb and click on it . It opened in Ubuntu Software center. And it shows the error
 cant install libc6:i386
so i found this below command and i tried it on terminal.
  sudo apt-get install libc6-amd64 libc6
but it shows some error.
Reading package lists... Done
Building dependency tree
libc6 is already the newest version.
  libc6-amd64:i386 : Depends: libc6:i386 (= 2.19-0ubuntu6) but it is not       going to be installed
any helps to solve and install teamviewer on my ubuntu 14.04 lts
Note : I have already read this articles. But no helps.
libc6:i386 : Depends: libgcc1:i386 but it is not going to be installed (on 14.04.2 64-bit)
still i am getting this error
varadha@varadha-X551CAP:~$ sudo dpkg --add-architecture i386
 varadha@varadha-X551CAP:~$ sudo apt-get -f install
 The following packages were automatically installed and are no longer     required:
 efibootmgr libtimezonemap1 secureboot-db
Use 'apt-get autoremove' to remove them.
 0 upgraded, 0 newly installed, 0 to remove and 49 not upgraded.
Kvvaradha
  • 233
Are you on Ubuntu 64 bits or 32 bits ? Have you downloaded Teamviewer 64 bits or 32 bits ?
In my case, when I was under Ubuntu 14.04 64 bits, I remember that I had to use TeamViewer 32 bit for making it working.
-1
I had the same problem, too. Please check your repositories in source list, because my wrong is put repositories ubuntu 14.04 for my ubuntu 15.04. Now, I have solved my problem.
