after upgrading to the newest version I can't start up my pc. I receive the error: The system is running in low-graphics mode
After looking into the forums, I go into the terminal (Ctrl + Alt + F1) I assumed this could be related to graphic drivers.
It seems I need to install libc6-i386, but the dependencies are broken:
$ sudo apt-get install libc6:i386
Reading package lists... Done
Building dependency tree
 libc6:i386 : Depends: libgcc1:i386 but it is not going to be installed
I'm very noob. Not sure what details you would need.
Output of apt-cache policy libgcc1:i386 is
libgcc1:i386:
installed version: 1:4.7.3-1ubuntu1
candidate: 1:4.7.3-1ubuntu1
table of versions:
*** 1:4.7.3-1ubuntu1 0
500 http://sk.arcive.ubuntu.com/ubuntu/ raring/main i386 Packages
100 /var/lib/dpkg/status
kiri
  • 28,986
If sudo apt-get -f install removed lots of packages and still have internet connection you may want to install ubuntu-desktop again:
sudo apt-get install ubuntu-desktop
That should make it.
Braiam
  • 69,112
