I recently upgraded from 12.04 to 14.04. After upgrading things started to break.
I am getting crt1.o: No such file: No such file or directory. So, I tried to install gcc-multilib, but, that is also running into errors.
$ sudo apt-get install gcc-multilib
Reading package lists... Done
Building dependency tree
gcc-multilib : Depends: gcc-4.8-multilib (>= 4.8.2-5~) but it is not going to be installed
I tried
$ sudo apt-get -o Debug::pkgProblemResolver=yes dist-upgrade
Calculating upgrade... Starting pkgProblemResolver with broken count: 0
Starting 2 pkgProblemResolver with broken count: 0
Done
Done
Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I tried to post the output of the following commands but I am unable to do it.
cat /etc/apt/sources.list
cat /etc/apt/sources.list.d/*
How can I resolve this?
$ sudo apt-get install gcc-4.8-multilib
gcc-4.8-multilib : Depends: lib32gcc-4.8-dev (= 4.8.2-19ubuntu1) but it is not going to be installed
Depends: libx32gcc-4.8-dev (= 4.8.2-19ubuntu1) but it is not going to be installed
$ sudo apt-get install lib32gcc-4.8-dev
lib32gcc-4.8-dev : Depends: lib32gcc1 (>= 1:4.8.2-19ubuntu1) but it is not going to be installed
Depends: libx32gcc1 (>= 1:4.8.2-19ubuntu1) but it is not going to be installed
Depends: lib32asan0 (>= 4.8.2-19ubuntu1) but it is not going to be installed
Depends: libx32asan0 (>= 4.8.2-19ubuntu1) but it is not going to be installed
$ sudo apt-get install lib32gcc1 libx32gcc1 lib32asan0 libx32asan0
lib32gcc1 : Depends: gcc-4.9-base (= 4.9-20140406-0ubuntu1) but 4.9.1-0ubuntu1 is to be installed
libx32gcc1 : Depends: gcc-4.9-base (= 4.9-20140406-0ubuntu1) but 4.9.1-0ubuntu1 is to be installed
$ apt-cache policy lib32gcc-4.8-dev lib32gcc1 gcc-4.9-base
lib32gcc-4.8-dev:
Installed: (none)
Candidate: 4.8.2-19ubuntu1
Version table:
4.8.2-19ubuntu1 0
500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
lib32gcc1:
Installed: (none)
Candidate: 1:4.9-20140406-0ubuntu1
Version table:
1:4.9.1-0ubuntu1 0
100 /var/lib/dpkg/status
1:4.9-20140406-0ubuntu1 0
gcc-4.9-base:
Installed: 4.9.1-0ubuntu1
Candidate: 4.9.1-0ubuntu1
Version table:
*** 4.9.1-0ubuntu1 0
Link to the output of sudo apt-get update: http://paste.ubuntu.com/9810181/
