I am installing p4v in /opt, but /usr/bin is on my path. Is it possible to create a soft or symbolic link for p4v from /opt to /usr/bin, so I can just type "p4v" since /usr/bin is in my path?
See man ln.
To create a symlink at /usr/bin/bar which references the original file /opt/foo, use:
ln -s /opt/foo /usr/bin/bar
You would need to apply the above command as root (i.e. with sudo).
- 2,692
- 28,899
The error is that you are writing the command wrong. The correct way is
ln -s /<full>/<path>/<to>/<file> /usr/local/bin
- 55,453
If the 'p4v' executable is at /opt/bin/p4v, you can simply run:
sudo ln -s /opt/bin/p4v /usr/bin/p4v
sudo chmod ugo+x /usr/bin/p4v
It would be better to add /opt/bin (or wherever the executable is) to your path:
echo "export PATH=\$PATH:/opt/bin" >> ~/.profile
reset
- 37,734
This template was more helpful for me than the above answers. Probably not more correct, just less obfuscated:
ln -s <path/to/real/file-or-folder> <symlink path>
Just replace the parts in <>'s
- 11,658
- 71
Check the software location by this.
which application-name #replace for the application you are looking for
for example
which skype
output will be this.
/usr/bin/skype
To create the soft link. for example you want to create the soft link for skype on your desktop
ln -s /usr/bin/skype ~/Desktop/
For more information about ln.
man ln
or
ln --help
- 1,968
ln -s -n ./TargetDirectory ./Nickname
Note, this works if you both nodes are below you in the same tree. You can use relative notation
- -s command makes it a symbolic link
- -n makes it possible de create a folder-type symlink
- 207,228
- 141
- 3
I have found that it is easier to go to where you want the link to be and then create the link using sudo ln -s /path/to/source/file, than doing ln -s target source.
So in your case I would do cd /usr/bin then sudo ln -s /opt/bin/pv4. The other way has not been working in my case.
- 181
