10
since some days my Files lens opens only nautilus but not the correct application which is associated with the file extension. For example, if I choose a PDF file, Nautilus is openend, pointing to the directory there the file is (and the file is selected) but Adobe Reader is not opened.
Then I do the same in the terminal with
xdg-open sample.pdf
only Nautilus is opened too.
xdg-mime shows me this info:
$ xdg-mime query default application/pdf
acroread.desktop
The /usr/share/applications/acroread.desktop file:
[Desktop Entry]
Name=Adobe Reader 9
MimeType=application/pdf;application/vnd.fdf;application/vnd.adobe.pdx;application/vnd.adobe.xdp+xml;application/vnd.adobe.xfdf;
Exec=acroread
Type=Application
GenericName=PDF Viewer
Terminal=false
Icon=AdobeReader9
Caption=PDF Viewer
X-KDE-StartupNotify=false
Categories=Application;Office;Viewer;X-Red-Hat-Base;
InitialPreference=9
The same with other file types like images, music files and office documents.
Then I doubleclick the file in Nautilus everything is ok and the correct applications are opened.
I assume this behaviour has something to do with Thunar which I've installed some days ago but deinstalled after these problems.
Any suggestions?
che---
  • 153
5 Answers5
I had the same problem when I installed xfce (my question can be found here).
My problem was solved after uninstalling all xubuntu*, xfdesktop4* and xfce4* packages (and thunar).
Perhaps you should start by typing:
aptitude search xfce xfd xubuntu | grep ^i
in order to see which packages are installed in your system.
Then proceed with their uninstallation.
Pavlos G.
  • 8,954
I had the same issue with the files-lens as well as in Chrome browser. I removed all xfce4 related packages and it fixed the issue. Thanks!
This is what I did,
sudo aptitude purge xfce4 desktop-base exo-utils gtk2-engines-xfce libexo-1-0 libexo-common libgarcon-1-0 libgarcon-common libthunarx-2-0 libtumbler-1-0 libxfce4ui-1-0 libxfce4util-bin libxfce4util-common libxfce4util4 libxfconf-0-2 orage tango-icon-theme thunar thunar-data thunar-volman tumbler tumbler-common xfce-keyboard-shortcuts xfce4 xfce4-appfinder xfce4-mixer xfce4-panel xfce4-session xfce4-settings xfce4-utils xfconf xfdesktop4 xfdesktop4-data xfwm4 xfwm4-themes
I found this information here
rak_qw
It is a bug in exo-utils / exo-file-manager.desktop:
https://bugs.launchpad.net/ubuntu/+source/exo/+bug/956255
blueyed
  • 9,125
This is a bug, but one way of solving (working-around) the problem is to make your own version of xdg-open:
mkdir -p ~/bin
cp /usr/bin/xdg-open ~/bin
You will need to make sure you have ~/bin added to your path. Your ~/.bashrc file should contain something like the following in it (it may already be there):
if [ -d ~/bin ]; then
    export PATH=~/bin:$PATH
fi
Now you need to edit ~/bin/xdg-open and add the following line after the line which only contains the text detectDE in it (around line 525 in my version of the script):
DE=xfce
After logging out and back in, documents should open with their associated handlers, instead of with Nautilus.
Mark
  • 1,479
I solved deleting (or commenting with a #) this line from file ~/.local/share/applications/mimeapps.list:
x-scheme-handler/file=nautilus.desktop
Stefano
  • 2,394
